Hot start problems. I need help
Old Sep 28, 2010 | 10:55 AM
todd jo's Avatar
todd jo
Slow to turn over when cranking. Like the battery has one turn left.
Old Sep 28, 2010 | 11:37 AM
7Ford6's Avatar
7Ford6
Have you had the battery load tested to make sure it's top notch? Also, I agree with the ignition timing check as well...
Old Sep 28, 2010 | 12:34 PM
todd jo's Avatar
todd jo
Yes I did load test the battery. I then changed the battery out of one of my other rigs. Same thing all over again. I will go buy a timing light and and start with timing at 10 degrees and see if the problem persists.
Old Sep 28, 2010 | 02:46 PM
Under-Drive's Avatar
Under-Drive
Hiya Todd,
I've read thru your postings and if your satisfied with the condition of your starter, battery, and cables I would look a little deeper into the motor. Basically, I'd pull the spark plugs out with the motor cold and see how hard it is to turn it over, at least two complete turns, at the crankshaft pulley, maybe even measuring the torque required to turn it over with an old-type torque wrench-the torsion type with the pointer and gauge. Then warm it up and do the same, plugs removed and note the torque required to roll the motor two complete turns. The rolling resistance should be less with a warm motor than a cold motor. If it takes more torque or there is a tight spot while rotating the crank go one step further and pull the bolts that hold the converter to the flex plate to isolate possible tranny problems. If it's still hard to roll over you may need to look into the motor, or the trans if disconnecting it freed up the rotating mass.
Just a few ideas, hope it helps.
Old Oct 2, 2010 | 08:50 PM
todd jo's Avatar
todd jo
Well I found the vac advance can was shot. I bought a new one, afraid I would lose the little "e" shaped clip that holds the arm to the advance plate, I decided to pull the dizzy. Put it all together and went to stab the dizzy back and the oil pump drive rod fell out into the pan while I was puttin back in. Didnt know it until I fired it up and had no oil pressure and loud noises! Bent the crap out of the drive shaft and broke the piston skirt off of #2 on the non thrust side. Discovered the oil pump pick up was nearly clogged with hard black plastic chunks of "????" Any clue what the plastic is from?
Now I gotta tear this motha down! I am thinking about transplanting entire drive train, axles, sheet metal, and long bed onto the 78 crew. Wifes been wantin one to go away for a long time.
Old Oct 2, 2010 | 11:06 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Most likely hardened valve stem seals...
Josh
Old Oct 3, 2010 | 03:40 AM
todd jo's Avatar
todd jo
That too is reasuring
Old Oct 3, 2010 | 09:34 AM
79 f350ts's Avatar
79 f350ts
Josh
could also be nylon from factory timing gears
Old Oct 3, 2010 | 10:10 AM
Bullitt390's Avatar
Bullitt390
Those OEM teeth are usually white.
Josh
Old Oct 3, 2010 | 10:42 AM
79 f350ts's Avatar
79 f350ts
Josh
true, but who knows after soaking in oil for God knows how many years?
Old Oct 9, 2010 | 06:24 PM
todd jo's Avatar
todd jo
Alright, yesterday I did a compression check on the cold motor. Compression ranged from 220 psig to 180 psig with one cylinder at 155psig. I dont know what the compression should have measured but even 155 as the low was higher than expected. I aslo think that 220 to 155 is a red flag, but nothing I can deal with right now.
Let the engine do its heat soak thing. Pulled the plugs and it spun over like butter. Did a compression check again had a presuure gain of 15-20 psig all around. Put them back in and got the no start deal. At least know I know this is a compression related problem, I just dont know how to deal with it. Any thoughts.
Old Oct 9, 2010 | 06:57 PM
sgtrwg's Avatar
sgtrwg
I had a hot start problem with the 302 in my 78 some time ago, replaced the ignition module, rotor, distributor cap, wires plugs, coil and the problem persisted. Finally I pulled the distributor and found that it did not turn freely at least as free as I thought it should so I replaced it with a rebuilt from Advanced Auto and have not had a hot start problem since.
Bob G
Old Oct 10, 2010 | 10:03 AM
  #28
Under-Drive
Loosen the dizzy and retard the timing just a little before trying to restart the warm motor, may be a timing issue.
dda140
Nov 25, 2014 09:54 AM
Rbones
Sep 7, 2012 08:01 PM
free_loaderz
Sep 22, 2010 06:39 PM
TCELasVegas
Feb 5, 2006 05:30 PM
1979fordf150
May 23, 2005 07:35 PM
