Dam these X's are hard work.Just got the cluster sorted and now the dam remote locking just packed up.Checked the fuses/but new batt in remote and still nothing.
Anyone had this problem.
Are your locks working? If so, then all you need to do is reprogram the remote to your ex.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Try to reprogram your remotes to your car. I'm sorry, I wrote the wrong instructions before. It's 8X within 10 seconds. Here it is. I will correct it up top as well.
