remote locking quit
Old Sep 25, 2010 | 09:08 PM
neilfromatl's Avatar
neilfromatl
remote locking quit
Dam these X's are hard work.Just got the cluster sorted and now the dam remote locking just packed up.Checked the fuses/but new batt in remote and still nothing.
Anyone had this problem.
Neil
Old Sep 26, 2010 | 09:46 AM
jh818's Avatar
jh818
Are your locks working? If so, then all you need to do is reprogram the remote to your ex.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Old Sep 26, 2010 | 02:14 PM
neilfromatl
Yeh the locks work but if you insert the key into the door it does not lock or unlock the other doors
Old Sep 26, 2010 | 02:46 PM
jh818's Avatar
jh818
When you press the power door lock button, does the locks work?
Old Sep 26, 2010 | 03:19 PM
neilfromatl
yes that works fine
Old Sep 26, 2010 | 08:45 PM
jdw1's Avatar
jdw1
What are we working on?
Old Sep 26, 2010 | 09:01 PM
jh818's Avatar
jh818
Try to reprogram your remotes to your car. I'm sorry, I wrote the wrong instructions before. It's 8X within 10 seconds. Here it is. I will correct it up top as well.
Old Sep 26, 2010 | 09:29 PM
neilfromatl
Thanks I will give it a go.
Seahn
Feb 7, 2025 03:05 PM
mrw1
Apr 9, 2011 11:32 AM
jp1096
Jan 6, 2011 10:26 PM
3rd car
Jun 22, 2009 08:54 PM
