4.2L need more power
Old Feb 21, 2003 | 11:59 AM
RINO's Avatar
RINO
I need more power for my little truck. I have sent hours looking for motor mods and other on the net and I cant find anything. If you you can help please do so.
Old Feb 23, 2003 | 03:08 AM
franktheman's Avatar
franktheman
I'll put this to you gently....from my experiences with the 4.2L-I'd say just be glad if you can keep it together-forget modding anything.
You say you NEED more power?
Way I see it -you got 2 choices,either live with what it's got,or buy a small v-8.
I blew my 4.2L-but in all fairness I prolly worked it a bit harder than most- and I really shoulda got a 3/4 ton -but still , I can't imagine this engine holding up under any kind of serious modifications.
Sorry to be the party pooper, with any luck someone who has possibly had success with this motor/w mods will get with you on it-but I doubt it.
Hope I was of some help.
Regards.
Old Feb 23, 2003 | 05:16 PM
BrianA's Avatar
BrianA
I think Frank is correct. I don't know of a good way to get reliable, substantial power increases out of the 4.2. If I were to do anything, I'd consider a chip. It will change the timing advance curve, remap the fuel injection, and provided you have an automatic transmission, alter the shift points. The FTE online store sells them: http://motorhaven.autoanything.com/
Worth considering but will require premium gas to take full advantage of the timing advance. As I understand it, without premium fuel, the knock sensors can retard timing and you'll not get all the advantage the chip offers. I might be in error on some specifics, but you get the picture.
The 4.2 tends to get a bad rap - especiall the early model years. Mine (2000 model) has 85,000 completely trouble free miles. In my case the 4.2 does fine for pulling the boat, utility trailer, motorcycle trailer etc. Nothing ever over 3,000 lbs.
But, if you NEED more power I'd look into trading for a V8.
Best of luck,
Brian A
Old Feb 23, 2003 | 09:19 PM
99F150's Avatar
99F150
The 4.2 has more HP per cube than the 5.4V8. but any way go to this web site they can help you out. www.supersixmotorsports.com
Dan
Old Mar 13, 2003 | 02:43 AM
coonass's Avatar
coonass
New to sight. To answer a few questions about power in the V-6. There are several ways to go. The most common are intake, exhaust (not headers), electric fans, then you can really step-up to bigger throttle body, larger injectors, port/polish heads, and bolt on supercharger. There are a lot of mods out there, some cost more than others. Lets stick with the basics: get a good quality washable air filter, add exhaust (do not go over 2.5"), chip, and electric fans. those mods should give you at least 30 hp at the rear wheels. Hope this helps and good luck.
GwarForAll1021
2004 - 2008 F150
25
Feb 26, 2009 09:20 AM
RickM57
Modular V8 (4.6L, 5.4L)
Feb 20, 2007 09:56 PM
85'FordF-150
May 21, 2004 09:58 AM
Ken00
1983 - 2012 Ranger & B-Series
Oct 27, 2002 08:18 PM
maxwedge1964
May 14, 2002 10:16 AM
