Trans Temp Gauge install
Old Sep 25, 2010 | 09:02 PM
Shooter00's Avatar
Shooter00
Fellas-
Any idea where to tap into my C6 to hook up my new Autometer mechanical gauge? It has a 1/2" NPT I think, but I can get a 3/8" NPT for it, which is what I did for the water temp.
Thanks!
Old Sep 25, 2010 | 10:50 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The output from the tranny pump is the most accurate temperature.
I personally used a Tee'd into the cooler line just before the transmission coolers.
Josh
Old Sep 26, 2010 | 09:39 AM
Shooter00's Avatar
Shooter00
Looks like it'll be more trouble than it's worth, I don't plan on pulling anything with it. I thought it would be an easy access plug and play, might save the gauge for my DD that I do tow with.
I'm using the 2 1/16 guages, and found the matching mini tach last night on Jegs website. I think I would benifit more from that anyhow. I haven't put a tach on just because I didn't like the idea of a huge column mount, so the mini would be a good fit.
Thanks!
Old Sep 26, 2010 | 02:22 PM
Bullitt390's Avatar
Bullitt390
It's not a big deal to install it, but if you are running aftermarket coolers, especially a bigger one, you shouldn't have problems.
I ran dual coolers and the normal running temp for my C6 with 3000 stall covertor was 170 degrees.
Josh
Old Sep 26, 2010 | 03:28 PM
Shooter00's Avatar
Shooter00
I am running a factory cooler, I'll take a better look at it. Thanks!
riverratmike
Modular V10 (6.8l)
Jan 19, 2018 11:05 AM
lisagoud
Jul 6, 2016 05:14 PM
genscripter
29
Jun 27, 2014 04:24 AM
larspetter123
23
Aug 19, 2011 04:54 PM
01raptor
Apr 12, 2011 06:56 AM
