Is this tire switch crazy?
Old Sep 25, 2010 | 07:15 PM
Fat_Tire's Avatar
Fat_Tire
I have a F350 CC LWB 6.7 on the way. It has the 3.31 gearing with the stock LT275/70R18 tires... 33" dia 626 revs/mile. I'm thinking about swapping these out for Toyo LT285/75 R18 tires... 35" dia 591 revs/mile. I understand they will fit the factory rims and won't require a lift. That's a 5% change in RPMs. Is that gonna significantly affect my power. I'm not towing anything heavier than a 20 ft bassboat... although we do have some pretty steep grades out here in Az. And... will I have to have my speedometer/odometer re-calibrated? Sorry... don't know much about this stuff... always stayed with stock tire sizes on my duallies.
Old Sep 25, 2010 | 08:21 PM
cowmilker08's Avatar
cowmilker08
That will equal a 5% reduction in torque.
How much does the boat/trailer weigh?
Yes you will need to recalibrate the speedometer. It will read 5% slow.
Old Sep 25, 2010 | 08:32 PM
Fat_Tire's Avatar
Fat_Tire
3500 pounds tops. So it can be re-calibrated... right?
Old Sep 25, 2010 | 08:35 PM
Fat_Tire's Avatar
Fat_Tire
5% reduction in torque... hmm that's about half the gain I would get with the new flash, right?
Old Sep 25, 2010 | 08:56 PM
FORDTUF1's Avatar
FORDTUF1
I don't think there will be a noticeable difference going to that size, not with these engines. Don't know about recalibrating for tire size, I think it was an option in the manual but can't remember.
If not I wouldn't worry about it, just expect it to be about 2 or 3 mph off and go with it.
Old Sep 25, 2010 | 09:02 PM
cowmilker08
Close enough, lol. You should be able to pull that easily. I've pulled 44,000 lbs. of corn with my old truck. 215 HP, 425 lb.ft torque, 3.55 gears, E4OD, so yeah you should be fine. lol. I could only pull it 15 mph, that's about as fast as you pull 2 gravity unload grain wagons no matter how much HP you have.
Old Sep 25, 2010 | 11:13 PM
biz4two's Avatar
biz4two
Thumbs up
YES...you should be able to tow your boat very easily...with little change in power. You might lose mpg, but that should be expected with larger tires and "high" gears.
YES...the dealer will recalibrate your speedo. The revs per mile are all you need...and you should be good to go. The importance is really two fold on the recalibration. 1st is for the correct speed reading and mpg, but also to keep the tranny happy shifting. Many...and I mean many a tranny has burnt up with larger tires as a primary reason, because it changes the shift pattern.
Good luck...your SD should look sharp with the setup in mind.
biz
Old Sep 26, 2010 | 01:52 PM
summet20's Avatar
summet20
I have a 2011 F-350 SC Dually with 3:73's that I plan replacing the 245's with 6 new 285/75/17's. Using a specialy made spacer for the rear wheels. With 3:73 gears like I had on the previous truck I don't think I will loose any mpg's or power. Actually the truck got better fuel mileage with em.
Old Sep 26, 2010 | 02:08 PM
srkr's Avatar
srkr
I JUST WENT TO 295/70 R18'S Nitto with the 3.31.Was told my MPH would be about 3MPH more. Looks better, I like the look and the ride. Don't worry. Do what you like.
Shane
Old Sep 26, 2010 | 02:24 PM
cowmilker08
3 MPH at what speed?
What not just recalibrate it?
Old Sep 26, 2010 | 02:53 PM
adamtheman16's Avatar
adamtheman16
3 MPH is 5% of 60 MPH. So the speedo would read 57 MPH @ 60 MPH.
So if you plan on a top speed of 80 MPH, 5% of 80 MPH (4 MPH) is going to read 76 MPH @ 80 MPH. So if your are cruising with a speedo reading of 80, your vehicle speed will be about 84.25 MPH.
I would program for the shifting purpose at least. the 5% sin't going to affect speed much at lower speeds, so driving over the speed limit isn't going make a difference. Even at 84.25 MPH, if the speed limit were that, you aren't even going 5 MPH over.
srkr's Avatar
srkr
60 mph
Shane
Old Sep 26, 2010 | 03:01 PM
Fat_Tire's Avatar
Fat_Tire
Shane
Shane, is this the tire? 34.4" dia and 604 revs/mile? Approximately 3.7% difference in RPM: Ratings, reviews and specifications for Nitto Terra Grappler AT tires
Old Sep 26, 2010 | 03:04 PM
cowmilker08
Why not just recalibrate it and be done with it? Why do you want to have to think about how fast you're really going everytime you look at the speedometer? I mean what does it cost and how long does it take to recalibrate the speedometer? I doubt its expensive or takes all day. You might even be able to recalibrate it yourself.
Old Sep 26, 2010 | 03:18 PM
srkr's Avatar
srkr
I don't and Won't worry about it. It's so minor of an issue.
Shane
