C6 issues
Old Sep 25, 2010 | 07:13 PM
bigten75's Avatar
bigten75
C6 issues
so i'm new to FTE and haven't really found what i am looking for so far in the search.
i have just purchased a 75 f150 king cab w/ a C6. it doesn't shift into third ever. not in drive, or if i manually put it in drive from 2 while driving. the tranny shifts fine from 1st to 2nd. the fluid is in good shape, but a little too full. i also replaced the vacuum modulator.
any words of advise?
thanks!
Old Sep 25, 2010 | 07:32 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Did you notice if the modulator pin was installed when replacing it?
Might have to pull the valve body and inspect for the check ***** and also do some air checks.
Josh
Old Sep 25, 2010 | 07:48 PM
bigten75's Avatar
bigten75
ya know- i feel silly- i didn't notice if the pin was in. i'll check that. if it turns out that the pin is installed, how big of a deal is it to check the check *****? i haven't done a whole lot of auto trans repair. just the basic replacement of filters and such. thanks for the help!!!
nathan
Old Sep 25, 2010 | 08:28 PM
Bullitt390's Avatar
Bullitt390
You just pull the valve body and check the locations, and also just visually inspect it.
When it comes to that someone will guide you thru it.
Josh
Old Sep 25, 2010 | 08:50 PM
bigten75's Avatar
bigten75
i can do that. i sounded more involved than that. thanks for the info!!
tjc295
Oct 29, 2010 04:23 PM
70efftoofifty
Oct 8, 2009 06:55 PM
Brian460
Sep 4, 2002 04:26 PM
