C-6 kickdown
Old Aug 24, 2002 | 12:12 AM
Brian460's Avatar
Brian460
C-6 kickdown
I have a 460 with a rebuilt C-6 behind it, it has extra clutches for 1st and drive, shift kit and all the other basic rebuild stuff.
The problem is no matter how fast you are going if you floor it, it is going into 2nd gear whether you like it or not. This wouldn't be bad if it was at normal 2nd gear speeds but I am talking about 75+mph, and that leaves my 460 screaming over 6000 rpm.
I've adjusted the linkage so that it only pushes the kickdown at WOT, but this left normal driving shifting way to early, and it still goes into second at a 75.
Right now I have resorted to leaving the linkage of and just manually shifting it, I know it won't hurt it but it knida defeats the purpose of having an automatic.
Brian
Old Aug 24, 2002 | 12:24 AM
ANIMAL's Avatar
ANIMAL
C-6 kickdown
I have a 79 f150 with a 400/c6 setup and I have the same problem. I sure would appreciate some help on this one
Old Aug 26, 2002 | 09:17 PM
Like M. Fords's Avatar
Like M. Fords
C-6 kickdown
You might try leaving the kickdown off and adjusting your shift points at the vacuum modulator. Pull the hose off, and you will see a screwdriver slot. Screwing-in should raise the RPM at which it shifts during take-off.
Old Sep 1, 2002 | 05:34 PM
redranger1's Avatar
redranger1
C-6 kickdown
Old Sep 4, 2002 | 12:47 PM
Steve_Uzi's Avatar
Steve_Uzi
C-6 kickdown
I have a 1984 Bronco w/460 C-6 Np-208. I had to get Lokar's C-6 Shift cable set-up. I have yet to install it (been mad busy @ work)
Been told this helps out and is 250% better than the stupid kickdown arm
Old Sep 4, 2002 | 04:26 PM
Brian460's Avatar
Brian460
C-6 kickdown
Hey, Steve is there a website with more info on this kickdown cable?
RC Dan
Sep 13, 2022 06:35 AM
pintojoe
Mar 24, 2015 12:10 PM
nlareau
Oct 1, 2011 12:45 PM
racinmike88
Oct 18, 2010 10:55 PM
deisele75
Dec 24, 2006 06:32 PM
