71 f100 360
Old Sep 25, 2010 | 06:51 PM
clayster's Avatar
clayster
71 f100 360
1st. post! Hello all my name is clay and i just picked up a 71 f100 360 sport custom. Truck is in pretty good shape, little rust and the motor seems to have been rebuilt in the last 10 yrs or so. purrs like a kitten just runs alittle hot..has a new radiator,hoses therostat so Im guessin the freeze plugs are going bad?
As I have inspected this truck over a few times I am baffled at the little handle that is in the interior of the truck, driver side...not hooked to the seat? I have a manual coming but hope someone can answer this for me?
Thanks again
Clay
Old Sep 25, 2010 | 07:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
If the handle is mounted on the floor outboard of the drivers seat, it's attached to the fuel valve that switches the In-Cab fuel tank to the optional 25 gallon auxillary tank and vice versa.
If factory, there is a toggle switch mounted to the left of the steering column that switches the dash fuel gauge from one tank to the other.
1970/72 F100/350 Stylesides: The 25 gallon auxillary tank is mounted on the inside of the drivers side frame rail. Has an exposed fuel cap/filler neck that pokes thru the drivers side quarter panel below the raised scallop line (Bumpside).
If the cap/filler neck is behind a fuel door, or is mounted elsewhere, or there are two (saddle) tanks, one right, one left...the tank(s) is/are not genuine Ford.
Old Sep 27, 2010 | 09:32 AM
clayster's Avatar
clayster
Thanks NumberDummy! got under the truck and looked..there is a space for the aux tank..just not there.
Old Feb 11, 2011 | 11:39 PM
Smoke_Dog's Avatar
Smoke_Dog
ND gave good advice I'm going to use it too!
Old Feb 12, 2011 | 12:35 AM
Railroader18's Avatar
Railroader18
how interesting, i just got my own 71 F100 with a newly rebuilt 360 engine. let me know how it goes i might steal some of your ideas though, lol.
Old Feb 13, 2011 | 01:05 AM
jhooch's Avatar
jhooch
Thanks again
Clay
Freeze plugs will not cause an engine to run hot unless they are missing or leaking and letting the coolant run out. How hot is a little hot? Do you have a gauge on it? Is the radiator large enough? When does it get hot, sitting in traffic? Is the ignition timing correct? Just ideas.
andy71
35
Oct 8, 2023 09:42 AM
dave3703
13
Dec 6, 2010 09:29 PM
mattg12b
May 20, 2006 06:02 AM
seventyone
May 16, 2004 04:34 PM
