1966 Brake Help
Old Sep 25, 2010 | 03:29 PM
jglee's Avatar
jglee
1966 Brake Help
I'm wondering if y'all can give me your thoughts on a brake problem I'm having on my '66. I just went through and redid pretty much the whole brake system. New pads, cylinders and hoses. The problem is is it takes a bunch of pressure to push the brake pedal when using the brakes. I'm not sure I could lock them up if I wanted to. A guy at the parts store said he thought it might be a blockage/stoppage in the brake line but they bled out good when I bled them.
Any ideas or suggestions?
Old Sep 25, 2010 | 03:58 PM
garbz2's Avatar
garbz2
Did you use the correct size lines?
Garbz
Old Sep 25, 2010 | 05:14 PM
jglee's Avatar
jglee
We didn't change the main line so I'm going to assume it is. But seeing some of the other stuff that's been done to it in the past I know that's dangerous. The hoses we changed are.
Old Sep 25, 2010 | 05:54 PM
66crawler's Avatar
66crawler
Did you put the shoes on correctly? Adjusted the shoes?
Old Sep 25, 2010 | 06:10 PM
jglee's Avatar
jglee
Yep. Doublechecked shoes 'cause the PO had all the larger shoes on the left side (which BTW is part of the reason we had to redo everything). Had one drum that needed turning and got that done so rechecked the adjustments.
Old Sep 25, 2010 | 07:08 PM
OldHarley's Avatar
OldHarley
Larger shoes go on rear side of each wheel, not "on the left side"! I apologize for my earlier statement.
Also shoes in the past were arched to match the drums. Don't think they do that any more, so it takes a little time to "wear in", then you need to re-adjust.
Last edited by OldHarley; Sep 27, 2010 at 10:13 AM. Reason: Revised location of where larger shoes go
Old Sep 25, 2010 | 08:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
A hard brake pedal is usually caused by a defective master cylinder.
I had the same problem on my '65...it was like stepping on a rock to get the darn thing to stop.
Old Sep 25, 2010 | 08:43 PM
jglee's Avatar
jglee
Greg, I thought the shorter pad (brake material) went on the forward side? That's what most references I've looked at showed.
Bill, I was afraid someone was gonna say that.
Old Sep 25, 2010 | 10:56 PM
OldHarley's Avatar
OldHarley
The smaller brake shoe goes to the front, but not because of why you might think!
These guys say larger shoe on front; their braking theory is correct, but their conclusion is WRONG!: Note: I went in and changed this so it would be correct!
Answers.com - Where doe's the bigger size brake shoe go front or rear in drum
These guys opinions mostly say back, but one answer is front:
brake shoes [Archive] - DoItYourself.com Community Forums
Proponents of the 'large shoe to the front' base that location on the FACT that the front shoe gives the best braking. It's TRUE, so why instead of the larger, it gets the smaller shoe??
Heres the best, worst worded description I came across:
The front shoe tries to jam itself into the brake drum - which makes it the stronger shoe braking-wise - when the brakes are applied - so it's smaller to match the power of the larger secondary shoe.
It's probably easier to remember this if we don't use the terms 'smaller shoe' and 'larger shoe', but think in terms of 'front shoe' and 'rear compensating shoe' - the larger shoe being on the rear to 'compensate' for the reduced the braking effect.
Old Sep 25, 2010 | 11:18 PM
66crawler's Avatar
66crawler
Wheres bill too make us all stupid...
Old Sep 25, 2010 | 11:27 PM
oldblu's Avatar
oldblu
The short shoe goes on the leading (front) side of each assembly. Master cylinder defect causing a HARD pedal? What kind of defect I must ask. Unless the piston is rusted solid in the bore, I don't think so.
I would want to know to what you are comparing this pedal effort. If you haven't driven one of these old trucks with normally operating brakes, it's not exactly like anything made in the last 30 years. You should be able to lock them up, but it takes a pretty good stomp. You might be experiencing "normal". You list a 2002 Ranger in your profile. That truck has disc brakes and I'm sure a power booster too.
If the truck stops straight, you've got the best sign of a properly operating system. If you run down the road 4-5 miles and you can slow the truck to a stop with minimal braking(use the tranny) I'd hop out and lay my hand on each drum or axle to check for a wheel with excessive heat. Then I'd drive it with several stops and check to see that each drum has generated the feel of equal heat. If you find a cold drum, you probably have a restricted hydraulic line to that wheel.
Old Sep 26, 2010 | 03:49 AM
NumberDummy
You don't think so?
I owned one of these trucks for 44 years (bought it new). When the pedal pressure became impossible, I asked the brake man at work what could be the cause. I replaced the master cylinder on his recommend...problem solved.
Old Sep 26, 2010 | 06:01 AM
camperspecial65's Avatar
camperspecial65
Another thing could possibly be the rubber flex hoses having collapsed inside of themself...when it happens no fluid will get through..had that happen on a friends Cadillac hearse...drove it like that for a long time before realizing...after we were rebuilding brakes. The hose looked and felt perfectly fine on the outside....but totally plugged inside...no fun trying to stop a 68 Cadillac with half its brakes non functioning...
If you replaced the flex hoses front AND rear try bleeding each wheel...when you do if each wheel shoots fluid at about the same pressure when you crack the bleeder then its gotta be the Master cylinder...if what you have been bleeding out isnt clear...or nearly so or has alot of crap in it...rusty color etc...that could be from the metal lines themselves rusting/corroding away inside...remember...brake fluid will draw moisture out of the air...and thus into the trucks hydraulic system.
Hope this helps, cs65
Old Sep 26, 2010 | 09:35 AM
jglee's Avatar
jglee
Oldblue, I know what you mean but this is really bad. I don't remember it being this way but it's been 30 years since I drove our old '65. It's like I think Bill said - you have to basically stand on it to stop. The good thing is it is stopping straight with no pull to either side. I'll go out this afternoon and check the drum temps like you said. I appreciate your help.
Old Sep 26, 2010 | 09:41 AM
jglee's Avatar
jglee
cs65, I'll look into that, too. Bleeding them again real good was gonna be my next try just to see if it would fix it before trying something more expensive. I'll check to see if the fluid is discolored in any way.
Okay, so if I have to try a new master cylinder - would y'all get a new one or is it worth trying one of the rebuild kits from the mailorder houses?
Also, I had been thinking about adding power. Is it worth it and would y'all go ahead and do it now while I'm working on the brake system?
Guys, I really appreciate all the help!
