customizing fule tank question
Old Sep 24, 2010 | 09:37 PM
ah1988's Avatar
ah1988
we have a fule tank that fits right up in the bed by the cab and
we were gonna install staks but we want to cut the corners of fule tank and weld them to fit up against stacks nicely .Problem is fule tank had diesel in it is there a way to clean the fule out of tank so when we
cut and weld it it dosent catch on fire from sparks
Old Sep 24, 2010 | 09:52 PM
Rick Wallace's Avatar
Rick Wallace
Welding on a fuel tank with fuell in it,,,,,,,,,,,, Before you start make sure and holler: Hey yall,watch this!!
Old Sep 24, 2010 | 09:54 PM
farmert's Avatar
farmert
Be vary carefull welding on fuel tanks. It is not the fuel but the vapors that will ignite when welding on them. I learned that the hard way. That said, remove all the fuel you can from the tank, then remove the caps and run an air hose from your air compressor into the tank and let the air run for an hour or so to remove any vapors. Then you should be good to go.
Old Sep 24, 2010 | 10:34 PM
banks7.3's Avatar
banks7.3
another option would be to move the tank back to clear the stacks, then build a custom storage box between your stacks that matches the finish of your tank. or cut a plate to fit between the front of the bed and the tank. both of these options would be easier and safer than welding on the tank.
Old Sep 24, 2010 | 10:47 PM
poocher pup's Avatar
poocher pup
rather than run compressed air into tank i would run shop-vac hose in filler and pull air out. diesel not as bad as gas though, when welded my mustang's tank filled it as full as possible with water.
Old Sep 24, 2010 | 11:25 PM
oreocreaming's Avatar
oreocreaming
dont bother running air into the tank, fire needs O2 to burn, so your not helpin anything. best thing to do is go down to your local welding shop (they are everywhere) and get a carbon dioxide tank. its a very heavy gas, non flamable and will keep you safe. just put a regulator on it, put the hose in the tank and pump it in. you can also fill it with exhaust from your gasser car or truck. same thing, it will fill with the carbon dioxide and push any oxygen and or vapor in there right out the top.
Old Sep 24, 2010 | 11:28 PM
oreocreaming
oh, and being a proud owner of a in bed tank, if i may suggest one thing. throw a baffle or two in that tank. you'll notice a difference when the tank is anything less then 3/4 full. it really can throw extra weight against you in a turn or effect your stop and go's. plus you'll feel it sloshing around for 2 minutes every time you come to a stop.
Old Sep 24, 2010 | 11:49 PM
poocher pup
yes a baffle would be a good idea as have hualed around barrels of oil and diesel and they can get to sloshing around pretty good to if not full.
Old Sep 25, 2010 | 08:55 AM
caelmalu's Avatar
caelmalu
I have seen welding done on a home heating oil tank done with the exhaust of the truck routed with make shift tubing into the tank to remove the air. It kinda looked like a precursor to a bad day, but it worked out fine.
Old Sep 25, 2010 | 09:11 AM
LCAM-01XA's Avatar
LCAM-01XA
+1 on this suggestion, seen it done and it looks nice and is functional too - depending no stacks diameter you can use the storage box for stuff like ropes and chains and spare fluids for the truck, even maybe some tools.
Old Sep 25, 2010 | 05:52 PM
Rick Wallace
X-2 !!!!!!!!!!
Old Sep 26, 2010 | 02:42 AM
kpjr's Avatar
kpjr
hmm sounds like an ex-girlfriend of mine. lol Couldn't resist.
Old Sep 26, 2010 | 10:47 AM
LCAM-01XA's Avatar
LCAM-01XA
Yah, those really have the habit of throwing their weight around you and also sloshing around in a turn - of course having a full vinyl bench seat that is flat as board may have something to do with it, lol... But I'm pretty sure that ain't quite what you meant
Old Sep 26, 2010 | 01:22 PM
kpjr's Avatar
kpjr
no, but it works too lol
Sexygumby
Mar 4, 2014 07:31 AM
ah1988
Sep 30, 2010 05:14 AM
ah1988
15
Sep 26, 2010 10:12 AM
6.9lXLTf250
13
Jul 12, 2010 12:28 AM
greasyjeep
Apr 3, 2007 08:07 PM
