Interchangeability
Old Sep 24, 2010 | 11:38 AM
mroth2008's Avatar
mroth2008
Interchangeability
Howdy quick question will a 54 256 4 barrel montclair intake work on a 57 2 barrel 272 truck heads? I've gotten mixed answer from researching and would like some clairity on it, pre 57 are suppose to have small ports right? and 57 up are so suppose to have large ports? Or would a egz-9425-A work better?
Old Sep 24, 2010 | 03:50 PM
charliemccraney's Avatar
charliemccraney
You might get it to seal for a short while but it will leak at some point.
'54 have the smallest ports, followed by 55 and I think 56, and '57 on have large ports.
The ECZ-A manifold will work. The ECZ-B manifold is better. It uses a Modern 4v pattern. The '54-'56 carburetors are for use with load-o-matic distributors; you can use them with '57 and up distributors, you just won't be able to make use of the vacuum advance without the appropriate vacuum source. If you're working with a '57 or newer engine, stick with the newer stuff and if working on an older engine with no concern about originality, swap to a new carb and distributor.
Old Sep 25, 2010 | 10:47 AM
mroth2008's Avatar
mroth2008
alright thanks for the info that clears everything right up
greenmachine55
Aug 1, 2014 02:28 PM
Damifiknow
Jan 3, 2014 05:47 PM
dansP350
Mar 1, 2013 05:56 PM
kooper909
Apr 8, 2007 09:47 PM
phoneman91
13
Oct 30, 2006 06:12 PM
