Correct speedo cable ?
Old Feb 21, 2003 | 07:24 AM
Andy63's Avatar
Andy63
Question Correct speedo cable ?
Hi all.
I have a 1963 F100 (not unibody). I am going through the process of converting the 3 speed manual trans to a C4 auto trans using a kit. The truck has the stock round type speedometer. I need to get a speedometer cable that will fit the stock speedometer and hook up to the C4 trans. There are a bunch of places to get the correct little gear for the C4 end. I have not been able to locate a source for a cable with housing and correct end ?
Thanks for the help
Andy63...
Old Feb 21, 2003 | 07:49 AM
Rosati's Avatar
Rosati
I modified my cable by cutting the housing about 18" from the head and splicing the donor sheathing to my OEM head connection. I used a large crimp on butt connector and two layers of heat shrink tubing to cover the splice. Only critical thing was cutting both sheaths to get the right length to fit the cable.
Old Feb 21, 2003 | 08:28 AM
Andy63's Avatar
Andy63
My housing is really a little bit of housing and mostly tape. The whole thing is rotted and falling apart. Was hoping to find a replacement source. Thanks for the help. I looked at your gallery. I was thinking about trying to find a donor car. But I lucked into the rebuilt 57 292 I put in my truck last year for really cheap so I thought trying to put a c4 in with a kit would be a good way to go.
Andy63...
Old Feb 21, 2003 | 12:51 PM
a63unibody's Avatar
a63unibody
Not sure about the C4, but I put a C6 in my truck and used the orginal [but new]cable.
Robert
Old Feb 22, 2003 | 12:14 AM
hawkrod's Avatar
hawkrod
just get a cable for a 1970 F100 with a 302 C4. they are available new and will fit fine. hawkrod
65fstback
19
Nov 2, 2013 05:05 AM
Myfreeford
May 30, 2012 09:09 PM
danlee
Nov 19, 2010 08:17 AM
