Window crank options
Old Sep 23, 2010 | 06:14 PM
66crawler's Avatar
66crawler
i know im beating a dead horse but has any one modified stripped regulators? I was thinking of maybe finding handles that had square inputs and I can grind the out puts square or I could make handles but that would be a pain in the but.
Old Sep 23, 2010 | 06:58 PM
Bill W's Avatar
Bill W
Whats wrong with a pair of vice grips?
Old Sep 23, 2010 | 07:12 PM
66crawler's Avatar
66crawler
Thats whats on there now lol! I would like handles if possible, kind of a pain in the but to use the vice grips. I have one handle thats striped out and missing the other. Id rather not replace the regulators seeing as my truck is used more offroad but it would be nice too roll up the window without scratching my primer lol.
Old Sep 23, 2010 | 07:20 PM
Bill W's Avatar
Bill W
I have an extra set of handles..... i may be up there next friday night if you plan to go meet a few of the chapter guy's.
Old Sep 23, 2010 | 07:46 PM
66crawler's Avatar
66crawler
Maybe, im trying to find some work right now as im freakin broke. I still need to re-do my exhaust and get that window from you, then get a gasket, all with no money lol. I hate my life haha.
Old Sep 23, 2010 | 08:23 PM
Customcab's Avatar
Customcab
If you where near me I have a set of regulators; I would give ya! This is not a open invit
ation too all; but if your in that kind of bind I would give you a set.
Hopefully a local member will help ya out!
Old Sep 23, 2010 | 08:33 PM
66crawler's Avatar
66crawler
Thanks customcab, the windows work so I was trying to come up with a cheap way to get some handles on.
Old Sep 24, 2010 | 10:21 AM
daveengelson's Avatar
daveengelson
Had a simular problem, if the grooves on the shaft handle are not too far gone took a mini file and reconditioned the grooves on the shaft and it has been working great since. Used a combination of small files, triangular, etc., what ever will recondition the grooves w/out rounding the edges. If this is an option, suggest replace the existing handle that has the damaged shaft.
Old Sep 24, 2010 | 12:08 PM
66f-100's Avatar
66f-100
My truck had vice grips for window cranks when I got it. I drilled all the through the shaft (it was ruined already) and used a longer set screw which went all the way through the shaft. Been holding up so far.
Old Sep 24, 2010 | 02:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All 1961/66 trucks (C/F/H/N/NT/T) use the same window crank handles, as do 1961/65 Econolines.
Old Sep 24, 2010 | 02:27 PM
66crawler's Avatar
66crawler
Thanks bill but factory dosent matter to me much, as long as it works and anything would look better than vice grips lol.
Old Sep 24, 2010 | 05:01 PM
baracade's Avatar
baracade
Smile
Hey Mitch, do you still want my old ford center caps? I have 4 but do not have all the screws!
Robert
labman1014
Aug 25, 2011 12:53 PM
Wayne S
Sep 17, 2010 02:20 PM
tomegun543
1997 - 2003 F150
Oct 30, 2006 11:53 PM
