4x4 steering column bushing
Old Sep 23, 2010 | 09:26 AM
BigJake34452's Avatar
BigJake34452
im having a hell of a time finding this bushing, its the lower one on the column. its a little plastic one. i've called everywhere and i went to national parts depot no one even lists such a thing, all i can find are ones for a 2wd column, any ideas on where to look?
Old Sep 23, 2010 | 09:32 AM
arctic y block's Avatar
arctic y block
Have you tried Ford directly? It,s possible there is one in there system yet. Maybe Bill Numberdummy will step in. He can find anything if it ever can be found.
Old Sep 23, 2010 | 09:47 AM
BigJake34452
o ok thanks, and also i just called carolina classics and they dont sell parts for this column because its a 78-79 style. also this is non tilt.
Old Sep 23, 2010 | 10:15 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Click on the .pdf link, is the part you're looking for basic p/n 3D681? If it is, the part number you need is:
Retainer assy, steering column lower bearing.
D3TZ-3D681-A Bearing, sleeve and retainer assy.
Fits 73-up F100-250 4WD from s/n S40,001
78-up F100-350
I couldn't locate any at the dealers I have access to.
File Type: pdf
Old Sep 23, 2010 | 10:26 AM
BigJake34452
78-up F100-350
yes that is it mike, i just went up to ford and had to find it in their books because they said there was no such thing (that was before i saw your reply w/ part number) they said they discontinued that assembly in 04 and no dealers nationwide has any.... i cant have the only column that has needed this assembly since 04 i hope someone knows where to get this. thanks for your help its greatly appreciated.
Old Jan 24, 2011 | 05:48 PM
Tgure's Avatar
Tgure
Any luck on finding this? I am also in need of this part my shaft is wobbling all over
Old Jan 24, 2011 | 07:29 PM
brownfoot's Avatar
brownfoot
I never had any luck either on that plastic part, none anywhere
do remember that bronco graveyard had a fabbed-up replacement, did not think very highly of it, so I made an aluminum one for my '76.
check if they still have it, should work ok, just looked junkie to me
Old Jan 24, 2011 | 09:43 PM
bobwires's Avatar
bobwires
aluminum eh?
I need the exact same part you're searching for, OP.
Old Jan 25, 2011 | 06:58 AM
Joseph69's Avatar
Joseph69
Old Jan 25, 2011 | 07:18 AM
70 Bronco TX's Avatar
70 Bronco TX
That's link is not to the right part...at least the one I understand we are talking about. I know because I need it, too, and looked at that piece before.
Old Jan 25, 2011 | 08:23 AM
brownfoot's Avatar
brownfoot
this is the JBG part I looked at:Column Bearing, Lower
Old Jan 25, 2011 | 12:29 PM
Pat B's Avatar
Pat B
The Column Bearing that brownfoot linked to is thway to go.
Pat
