engine swap
Old Sep 23, 2010 | 02:36 AM
j250hd's Avatar
j250hd
engine swap
Just wondering how hard it would be for a novice to take my blown engine out and put another one in? Any advice? Also will i run into any problems going from a 95 block to a 96?
Old Sep 23, 2010 | 07:45 AM
jacob_powerhouse's Avatar
jacob_powerhouse
pulling the engine is not hard. you pretty much remove the whole front end (everything between the fenders). just make sure you get everything diconnected from the engine. like the ground on rear/passenger side. there should be almost no difference. im not sure but there may be little things different between a '95 to '96, like a sensor as an example. but it should work just fine.
Old Sep 23, 2010 | 10:36 AM
Brown Falcon's Avatar
Brown Falcon
The HPOP is a bit different, but everything should work fine.
TheTowingCowboy
24
Feb 1, 2011 05:41 PM
poppajoeblow
Oct 6, 2008 02:03 PM
hughjazz
Feb 6, 2008 04:44 PM
Gage2502
Oct 11, 2007 10:02 AM
dburgess
19
Apr 28, 2004 09:23 AM
