1980 rear end numbers
Hey all,
I got these numbers off the tag on the rear end. I cleaned the tag as best I could and I'm fairly certain this is whats on there. Any help on them?
VD
MBK2
3K21
509
S31
To my knowledge, this is the original rear end
Thanks,
DS
VD
MBK2
3K21
509
S31
Thanks,
DS
I must be blind and/or stupid 'cuz this makes no sense. I've been searching the forums, web etc and make no sense of the 3K2150 9 S31
part of the tag. The dana 44 on the front had 3.50, obviously the gear ratio. I hardly believe there would be a 2.15 rear end gear with that in the front.
still working on it,
DS
part of the tag. The dana 44 on the front had 3.50, obviously the gear ratio. I hardly believe there would be a 2.15 rear end gear with that in the front.still working on it,
DS
I searched what info I have only 2. ratio is
Ford... 8.8"....... 3750....2.47
Unless it is not original and is out of a car. After the 2.47 it list 3.0 up to 4.11. You have me scratching my head.
Yes, you have a Ford 9" with a 3.50:1 ratio. Many times, the first number of the gear ratio on the bottom line is covered by the bolt holding the tag, in your case it's the "3" in "3 50 9 ...."
Thanks much for the info. I'll go ahead and take the bolt off and really clean the tag (blast, paint etc) and then reinstall it. I should also check to see if there is an L as well
Thanks x 10 to everyone,
DS
DS
'83 rear end numbers
I was scanning the threads for this same info for my own truck. The tag on my axle reads as follows:
3 54 E3TA CRA
605215 4 LS
I removed it, so I know the mounting holes aren't cutting any digits off. Can any one assist in telling me what my ratio is?
Thanks,
Mary
3 54 E3TA CRA
605215 4 LS
Thanks,
Mary
clydes 74 ford
15
Nov 6, 2017 11:40 PM
UnfoundFord
Aug 12, 2007 09:04 PM
silverz98
May 23, 2007 12:18 PM
