Is it ok on the mechanicals to run your part-time 4x4 in 4x3? Let's say you have twin Detroit lockers, and you lock one hub, but leave the other hub unlocked. This way, you have 4x3, and you don't have to fight the steering wheel like you would in 4x4 with twin lockers.
This wouldn't be hard on the mechanicals, would it?
easier to break **** if you run locked in the front with one hub unlocked. axles and etc. Because with open diff your inside tire (or the tire with the least traction) will spin. With one hub unlocked and the t case in 4wd and the diff locked, the unlocked tire will spin, whether its the easiest to spin or not.
Oh crap....my bad. I didnt understand your question,....you meant "hubs". I thought you meant run rear locked with front diff open....Agree with haste..
Thanks for the replies, if that's true, I won't do it.
Question though:
With a locker under load, torque is evenly split on both axles, only one axle isn't locked at the hub. Would this still be placing all the torque on the locked side, or only 50%?
Another way to put it:
Wouldn't it be the same thing as having both hubs locked in front, but one tire is on ice?
yes it would still apply all the torque to the one side...the other side will be spinning the same speed as the locked side, but there is nothing pushing back against it to break something.
If you have one tire on ice and one tire on say clean ashpalt then yes...BUT it would be just as hard as say an open diff with both tires on ashalt spinning one tire(burnout?).
Well, also consider that if you have all four locked and 4x4 engaged, that when you turn on a hard surface(pavement) you are putting tons of stress on one side of the axle as well b/c it has to hop that tire to make the turn.
Thats why you should only use 4x4 on a loose surface where you need the traction... Or get a selectable locker.
I disagree with those saying you'll break something with only one hub locked. You put it perfectly, it's like having one front tire on ice and the other on dirt. With a locker, both tires pull evenly and if only one is locked only that one pulls while the otherside axle spins harmlessly. I often have a tire in the air wheeling and the tire on the ground takes the whole load thru the driveline, but it works fine if you don't hammer it.
Where else can all the torque go, but to one side if the other is unlocked, airborne or broke? Doesn't hurt a thing, but more load is put on hub and axle, so don't hammer like you might with both locked.
No difference running only one hub locked and understand how hard it is steering with a locker. When you blow a hub or axle on a trail with a locker, it's standard practice to use the other hub to help you get out of there. The only time you wouldn't is if you were going to tear up otherwise reusable yokes on a blown axle u joint.
Run your 4x3 until you get the funds to beef up your steering to handle the locker or get a selectable locker.
