No smoke usually means no power to PCM or IDM. Check under dash fuse 30. If t is blown disconnect the fuel bowl heater connection (white connector) on back of fuel bowl and replace fuse.
Edit: Damn I'm slow. Just walked out to the garage and missed a bunch of posts.
I changed my GPR because the old one was bad and it wouldn't start in like 40 degrees weather. The only thing i notice about that is i hear it buzzing for like a minute then it shuts off. Its reading out that its sending the volts its supposed to.
All my fuses are good. Idk how to test the little relays. I do have one fuse i cant test its got an aluminum housing on it. It looks way different from the rest.
FIXED! Had to get a GREY CPS from advanced to get it going for now. I hear that you need a special CPS or it goes bad again. Can anyone tell me what im looking for for a good replacement?
Common wisdom says that (if you can get a hold of one) the original black CPS is what allows the engine to run the smoothest, with the most accurate injection timing.
I believe both RiffRaff and Diesel O-rings have them in stock.
