turbos
Old Oct 5, 2010 | 07:38 AM
turbo diesel fan's Avatar
turbo diesel fan
what does that even do does it open up and let more air in the turbo?
Old Oct 5, 2010 | 10:17 AM
16Vjohn's Avatar
16Vjohn
A cowl induction allows cooler air to enter the engine instead of sucking hot air from the engine bay. Although, I thought these trucks had a tube device that served the same purpose. Some will say that a cowl induction will have a "ram air" effect causing the turbo to get more air and make more power. While this may be true, the effect would likely be less than 1 horsepower and only at speeds greater than 55mph. Keep in mind that these trucks are an aerodynamic disaster really and there is a large area of low pressure the develops over the hood due to the movement of the air around the front of the truck in the grill area. You stick your hand out the window and you can feel a lot of air pressure, but it's much MUCH less at the center of the hood. I can't see a cowl induction being useful for anything more than looks. I think it would serve nearly the same purpose as the stock airbox. If your goal is to get more sound out of the turbo, I am sure this would accomplish that. But to cut a hole in your hood and install the cowl correctly (not half assed) is going to be expensive and I bet you wouldn't see even a fraction of 1hp improvement. On the other hand, if you did the 6637 filter thing, a cowl might serve a useful enough purpose to keep most of the hot air off the filter... since you completely remove the stock airbox and there's no way to keep the hot radiator air off it. You might have a small net gain in power and decreased turbo lag, but I bet you'd see an increase in EGTs especially if you didn't have an intercooler. That could have adverse effects on long term reliability and longevity.
My $0.02
Old Oct 6, 2010 | 02:16 PM
94 smokin stroker's Avatar
94 smokin stroker
well i now have my pyro trans and boost a pillar gauges on the beast so as soon as i get the intake pipe bent i will record egts and see im expecting either a drop or same as the stock intake but with better performance i dont know but i will post when i get it ready to test ill run with the stock then the 6637 and let you know results i know tht the air might be 10degres hotter but tht wont make a big difference considering i will be 3x the amount of air i was sucking before it should stay the same or drop
Old Oct 6, 2010 | 02:22 PM
16Vjohn's Avatar
16Vjohn
10 degrees? Try 50-60 degrees hotter. I would be interested in seeing the data.
jcalebw
Feb 25, 2014 04:34 PM
jayzeller79
Mar 1, 2008 08:22 AM
ford1183
20
Jan 13, 2008 02:57 PM
Mikey85
Jun 12, 2005 10:56 PM
ktplotts
May 10, 2005 12:05 PM
