I bought a 2001 f350 used I am the third owner.The guy that I bought it off of was the second owner and was clueless about the truck.The first owner had put some extras on the truck. I was just wondering if the turbo was one of them.I am running 25+ very easy i have to let out of it.
Well, you could have a van turbo, a Ballbuster/phatshaft type, or one of the ball bearing units not to mention a Holset or H2E. Why not post a pic of your setup. Bet someone can identify it. Might even be a stocker with a good tune.
If it has a 3" intake tube 99% its a stock turbo... If it has a 3" and a 1.15 housing (exhaust) then its a van turbo... Very doubtful that it has an aftermarket turbo...
What other mods do you have on the truck? Is there AM/ exhaust? Do you have a different intake then stock? Is there some kind of chip or programer on your truck?
Making 25# of boost is not very hard if you have a few mods.
my truck has a 3.50 in exhaust, bully dog 6pos chip and a ram air type intake the exhaust i have been told is stock but it has been cut right behind the cab and is turned down it also think it has a muffler but one person told me it was a resonator what ever that is.
thats a stock turbo..but there could be a wicked wheel in there..you need to pull the air intake tube to see the wheel..if you do that..see if the wheel has any chips or dusting..grab the nut and try to feel any play up and down side to side..very little play is ok..then pull in and out for any play..should be no play at all there..
the turbo on the left is the stock 99.5-03 turbo..it has the wicked wheel in it..every other fin is shorter then the other..on the stock wheel..all the fins are the same size...i have pictures of the stock wheel in my exploded view link in my sig..dont get confused..i messed up and took pictures of the stock wheel sitting on a Wicked wheel box...
