Windsheild swap
Old Sep 21, 2010 | 11:51 PM
Handegard's Avatar
Handegard
Windsheild swap
I have 2 '69s sitting here, the one I intend to save has a busted front window.
Any tips/tricks to swapping windows without breaking the donor window?
I assume it's held in with the same tar-like adhesive my 1969 Mustang had, perhaps a little heat will help?
Thanks,
Chris
Old Sep 22, 2010 | 12:12 AM
frankensteined_67's Avatar
frankensteined_67
the best way is to take a knife/razor blade and cut the rubber on the out side and have you on one side and some one on the other side. and gently push it out. to install it, pay someone. then you know its right.
Old Sep 22, 2010 | 11:39 AM
jackslater's Avatar
jackslater
Like Frankensteined67 said, cutting the rubber is the best way. I just removed a couple windshields. One of them didn't have anything but the rubber around the window and the other had black adhesive/sealer in it. Guess which one leaked?
When installing I highly recommend some kind of sealer in addition to the rubber.
gyrospinup
1997 - 2003 F150
Sep 16, 2011 09:43 PM
wertz49
May 10, 2009 12:23 AM
tanksgt
1997 - 2003 F150
Mar 15, 2008 07:40 PM
Chris_ce
1978 - 1996 Big Bronco
Jul 8, 2003 12:10 AM
MisterCMK
May 14, 2003 10:51 AM
