Oil pan replacement
Old Sep 22, 2010 | 10:50 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Originally Posted by johnsteffy
I'm going to just try loosening all the mounts and hoisting it. hopwfully it works...
Good luck, but maybe the turbo will be on the way.
Originally Posted by 97250hd-earl
Chicagodagon- george, the thread on the crossmember cut was by strokin-tatsch- travis.
Are you sure?, I also think was by Cuda Jim.
Old Sep 22, 2010 | 12:00 PM
johnsteffy's Avatar
johnsteffy
ill just pop the turbo off first and then give it a shot
Old Sep 22, 2010 | 12:19 PM
97250hd-earl's Avatar
97250hd-earl
roentgeep-what i remember was a post about a pickup tube crack and about 2-3 pages in they got into cutting the crossmember, I think you may have input in it, it was about year ago.
Old Sep 22, 2010 | 12:28 PM
C350CREW's Avatar
C350CREW
If you try removing the pan with the motor in the truck and it dont work, what have you lost, but if it works just think of the time you saved. some of the work you will be doing to just raise the motor in place is work you would be doing anyway to remove the engine.
Old Sep 22, 2010 | 12:44 PM
johnsteffy's Avatar
johnsteffy
thats a good point. i need to just get an oil pan and then this is happening. theres no deeper pans out there?
Old Sep 22, 2010 | 01:05 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Read this link:
https://www.ford-trucks.com/forums/9...werstroke.html
Till I know there are no deeper pans as stated above. Why do you want a deeper pan anyway?
Old Sep 22, 2010 | 01:11 PM
johnsteffy's Avatar
johnsteffy
i just was thinking since i am pulling the pan might as well go with a bigger one. i would like to start doing some work to my truck and i might as well do the best pan i can.
Old Sep 22, 2010 | 04:44 PM
chris64's Avatar
chris64
These oilpans are difficult to seal correctly. My pan leaked after I removed it, and I was very careful ( obviously not careful enough) . Getting all the surfaces clean, especially at the corners of rear main is key.
Good luck
C
Old Sep 22, 2010 | 07:23 PM
johnsteffy's Avatar
johnsteffy
thanks. i feel like just pulling the motor completely out is my best bet
bizzelj
Apr 12, 2015 06:20 AM
loveless41908
Jul 10, 2014 08:43 PM
WINGNUT-
13
Aug 14, 2011 07:59 PM
robjs111
1997 - 2003 F150
Apr 1, 2011 08:19 PM
psf
Aerostar
Dec 26, 2004 03:32 PM
