Rear Window Lock
Old Sep 21, 2010 | 09:08 PM
snavemit's Avatar
snavemit
Rear Window Lock
I have been searching all the threads on the rear window and have already made progress on my issue. Used some WD-40 and now my key can turn the lock but it only turns from the 11 oclock position to the 2 oclock position. So with this being my first Ex, how far is it supposed to turn? It turns and I hear a click, but nothing locks. Does this sound familiar to anyone? Is it the actuator? Should it be locking with that much turn?
Thanks
Old Sep 24, 2010 | 01:38 PM
under6ft's Avatar
under6ft
There are a few other threads on here that address this better, so do a search for "rear hatch lock" and you will find some good info. I just did mine and it works great now.
The key should turn from 3 O'Clock to about 9 O'Clock. 3 to unlock and 9 to lock. The key lock is attached to a a metal bar that extends over to the handle on your rear window. The mechanism is a brass colored piece of metal with two functions. One function is to lock/unlock the mechanism (connected to the metal bar connected to the key). The other is the rear handle. What is probably happening is that the lock/unlock is frozen due to dirt and so it won't allow you to turn the key all the way.
The pull down handle inside the vehicle comes of with two screws (Torx I believe) and then you can pull the panel off very easily. Just get your fingers or a screw driver in between the panel and the window and pull. Then their is a piece of plastic (dust screen) that is glued to the metal. Pull that off and then you should have access to the handle mechanism. I sprayed mine down with WD-40 and then just got in there with a tooth brush the best I could. I had to pull and push the metal bar that connects to the key lock to get the mechanism to lock/unlock. You should be able to see how it all works pretty easily once you have it open. Only took about 20 minutes. Good Luck!
deputydog03
Modular V8 (4.6L, 5.4L)
32
Apr 9, 2016 12:06 AM
46fordtruck
2004 - 2008 F150
Sep 20, 2014 02:32 PM
deputydog03
1997 - 2003 F150
Dec 11, 2013 01:45 PM
hawk1snest
Feb 24, 2012 02:10 PM
