front Axle
Old Sep 21, 2010 | 07:16 PM
maverickfe390's Avatar
maverickfe390
front Axle
Hey would a 1981 Ford 1/2 ton 4x4 front axle fit into a 1967 F-100 4x4 ?
Old Sep 21, 2010 | 09:58 PM
RichS2659's Avatar
RichS2659
Why would you want to change as your 67 has a stronger Dana 44 than the 81 TTB axle. The 81 frame is much wider and the radius arms are probably longer so I'm assuming that you would have to move the mounts. Is your 67 axle a closed knuckle or and open knuckle axle? Did you want disc brakes?
Old Sep 22, 2010 | 01:12 AM
mav4804's Avatar
mav4804
Thats what im try too do make is too put front dish's on the front
Old Sep 23, 2010 | 12:24 AM
RichS2659's Avatar
RichS2659
I'm not familiar with the 67 Dana 44 to know if it has a closed or open knuckle. If it is closed type, then it can't really be converted or it is real expensive, as in a very expensive kit, I believe, which has been mentioned on this site. Then you would have to swap axles with any disc brake equipped axle to 79 with the same ratio. If it is open knuckle, you might be able to swap outers with another disc brake equipped 44, which your TTB 44 might work as a donor, of which I don't know. Someone will chime in with the proper info.
Powermonger
Sep 29, 2011 06:35 AM
FORDMAN F2011
May 3, 2011 05:15 PM
TheresHellToPay
Nov 9, 2009 01:26 PM
slikness
Feb 28, 2002 12:55 AM
