Whats the bolt size that connects the part of the mount that goes through the crossmember? I thought it was 1/2" coarse but it seems too loose, tried 1/2" fine threads and that didnt work, I had to cut the old bolts out so I couldnt reuse them.
are you trying to reuse a trans mount? if so please stop and just get about 30 bucks together. Where you buy can get you new nuts for it. Mine was 34.99 and it has 5/8 bolts with coarse thread. Those are a wear item and need replaced every now and then.
No no I buy new one today drom advance autopart for $20 but the dont come with new bolts, I had to cut old ones off withs awzall because the studs rounded on the mount and wouldnt come off I think 5/8 would be too big if 1/2 is right now
should look like that and yes it is 7/16 i was thinking of my frame shackle bolts. apologies there but yeah it should have the bolts intact, unless you are talking about the ones that bolt it to the trans? if so then whatever fits, i know i have 1/2" bolts there.
