Sounds like a rock stuck in the tire. Trucks never seen gravel...
Old 09-20-2010, 06:50 PM
Brewskiie05's Avatar
Brewskiie05
Brewskiie05 is offline
When I have the windows down and driving at parking lot speed I hear a tick, tick, tick like you would hear if there was a rock stuck in the tread. The tires don't have enough tread to pick up a rock for one and this truck has never ever been off pavement ever. Its a 2001 F150 4x4 Lariat Crew Cab. Its kept super clean and always greased, and fluids changed every 3-5k miles.
Any thoughts?
Old 09-20-2010, 07:46 PM
jgeese's Avatar
jgeese
jgeese is offline
Check for anything that you may have run over. I have had nails, screws and pieces of metal stuck to, or in tires that didn't cause the tire to go flat.
Hope that helps...
Old 09-20-2010, 07:58 PM
Ultramagdan's Avatar
Ultramagdan
Ultramagdan is offline
Have you checked the u-joints? If they are really worn they will talk like that. jgeese's comment is also correct. Anything on the tire will make that noise.
Old 09-21-2010, 01:55 PM
SteevenH's Avatar
SteevenH
SteevenH is offline
ABS Sensor.
coolidge54
2017+ Super Duty
63
03-08-2019 12:03 PM
RainDesert
1999 to 2016 Super Duty
06-30-2016 08:16 AM
rvpuller
6.2L V8
04-10-2016 07:54 PM
JDW124
1997-2006 Expedition & Navigator
06-15-2010 09:27 PM
gcozmo
2004 - 2008 F150
35
01-09-2010 12:36 AM
Quick Reply: Sounds like a rock stuck in the tire. Trucks never seen gravel...
