1997 F150 2WD Lower Ball Joint Remover Tool Recommendations
I need to replace the lower ball joints on my 1997 2WD F150 pickup. I don't own a remover, so I'd like to buy one. Looking around, there's pickle forks, c-clamp styles, and "reverse" clamps designed to pry apart the joint as the clamping bolt is rotated in.
A good thing about some of the c-clamp styles is that they'll do double duty as u-joint tools.
I can go higher than the $40 HF wants, but I need to keep it under $125 or $150.
Thanks very much, I appreciate the help.
Dave
Dave
banjopicker66
24
04-08-2013 11:49 AM
