Brake Controller
Old Sep 20, 2010 | 06:31 PM
Vinford's Avatar
Vinford
Brake Controller
Has anyone got instruction for hooking up a brake controller?
Old Sep 21, 2010 | 09:34 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Do you already have the controller? What brand? If you already do have it, have you tried the manufacturer's web site? Or at least the "BIBLE" at the top of this thread?
Old Sep 21, 2010 | 11:56 AM
aklim's Avatar
aklim
See my pics
Old Sep 22, 2010 | 03:19 AM
TexasRebel's Avatar
TexasRebel
what are you hooking it into?
it should have four wires.
Black - 12v (hot with ignition through an auto-reset circuit breaker)
Blue - output to trailer
Red - spliced into the low side of the brake pedal switch
White - Ground
If you are putting it onto that F350 in your signature, it should already have the connections made with a plug & play harness ready for you. You just need the other side of that harness, match the colors, and plug it in. You will still have to install the 20A auto-reset circuit breaker though.
Old Sep 26, 2010 | 10:26 PM
Vinford's Avatar
Vinford
Sorry its going in a 94 F-250 2wdr with a automatic.
351 Engine.
Old Sep 26, 2010 | 11:36 PM
TexasRebel's Avatar
TexasRebel
if wiring doesn't already exist... you'll have to run wires to the connections yourself like I described in the previous post.
The blue wire will have to be run out of the firewall, along the frame, and to the trailer connection. Make sure there is an actual ground wire to the trailer connection, too.
Old Sep 27, 2010 | 04:21 PM
scububbs's Avatar
scububbs
I've had to do this a couple times over the years, the brake controller manufacturers always had great information on their websites. You should be able to get vehicle specific information without too much trouble.
scraprat
All Things Towing
Jan 4, 2015 09:16 AM
billybobzia
2009 - 2014 F150
Jun 10, 2014 04:53 PM
bama210
Modular V10 (6.8l)
19
Mar 13, 2009 10:58 AM
horsepuller
All Things Towing
Nov 7, 2006 02:59 AM
loudfords
All Things Towing
43
Oct 19, 2004 08:33 AM
