Catlytic converter
Old Sep 20, 2010 | 12:41 PM
Buck123's Avatar
Buck123
Catlytic converter
if i take my catalytic converter off my 95' Ford F-150 with a 5L engine will it affect how it runs? thanks
Old Sep 20, 2010 | 12:57 PM
IowanStraight6's Avatar
IowanStraight6
is it obd I or obd II
Old Sep 20, 2010 | 08:34 PM
TexasGuy001's Avatar
TexasGuy001
It should be OBDI. The first year for OBDII was 96. As long as it only has 1 O2 sensor in front of the cats then it should e fine. Just keep in mind that you may have to pass emissions tests at some point.
Old Sep 21, 2010 | 11:03 PM
twigsV10's Avatar
twigsV10
Smashing the cats on my 94 helped alot, but the empty cats droned a bit. Didnt mind though.
Old Sep 22, 2010 | 07:02 AM
fordyduty's Avatar
fordyduty
Better flowing exhuast = more power and better mpg. Exactly how much you would gain is questionable and dependent on your situation and the current condition of your motor. If you have an o2 sensor after the cat then you will have a cel on. If your going as far as to hollow or remove the cat or cats then put a good flowing muffler on too. I 'm sure someone will chime in and tell you about the legal end of things!
Old Sep 23, 2010 | 10:48 AM
IowanStraight6
if im not mistaken some late year 95s wear obd II
Old May 2, 2013 | 07:46 PM
FordFARMTRUCKS's Avatar
FordFARMTRUCKS
I removed the cats on my 90 F150 302 and it made a hell of a difference. I kept the o2 sensor in the front of the cat by cutting the pipes right where they enter the cat and welded together a Y pipe from a bunch of reducers and a Y pipe from Car Quest. After that i ran 2.5 inch strait pipe with a glass pack. It sounds amazing and has really made my motor run better.
tmh1331
2004 - 2008 F150
Nov 4, 2011 01:03 PM
48fordf3
26
Feb 15, 2010 11:59 PM
roddy79
Jul 8, 2008 06:05 PM
Oaktree
General Automotive Discussion
Apr 1, 2008 07:42 PM
Dragrazor
May 27, 2003 08:13 PM
