Vandalized
Old Sep 20, 2010 | 08:15 AM
gteddie's Avatar
gteddie
Vandalized
So i woke up today and found vasoline spread over most of the windows and over the door handles, as well as some of the paint....Is there any good way of getting this off without smearing it?
Old Sep 20, 2010 | 08:56 AM
smashclash's Avatar
smashclash
I would try blotting it up as much as possible with paper towels/rags. Do your best not to smear it. Instead try to "pick it up." Once you got as much off as you can I'd hit it with a degreaser like a Joy or Palmolive with soap and water. You've gone this far might as well wash the whole truck!
Old Sep 20, 2010 | 09:15 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I find Dawn dishsoap works the best on oils and greases.
I would pour straight Dawn on it, work it in until it lifts it off the vehicle then rinse with lots of water.
-Enjoy
fh : )_~
Old Sep 20, 2010 | 12:28 PM
1986F150six's Avatar
1986F150six
And then be prepared to wax. The dish detergents are good at degreasing and removing the wax.
Old Sep 20, 2010 | 02:59 PM
Holmesuser01's Avatar
Holmesuser01
Somebody must really like you. I've not seen Vaseline used like this for years!
Any ideas why they singled you out, yet?
At least they didnt pour paint over your truck.
Old Sep 20, 2010 | 03:25 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I would use a car wash concentrate.
Dawn and other degreasers could theoretically damage the clear coat paint, if it has one that is. 1985-1986 models with factory paint, etc, and trucks repainted with clear coats.
If you do use a dish soap, make sure you treat the rubber seals with some type of protectant to keep it from cracking. Believe it or not, vaseline is a good plastic and rubber protectant, as well as silicone lubricant.
Again don't get the silicone lubricant on the paint as it too can damage the clearcoat.
Old Sep 20, 2010 | 07:29 PM
gteddie's Avatar
gteddie
Actually I was 1 of about 25 in a parking lot that got hit overnight. But thanks for all the help it came right off!
Old Sep 20, 2010 | 08:01 PM
Eddiec1564's Avatar
Eddiec1564
You got lucky it was vaseline. Some sob used brake fluid on my car once. Had to get another paint job. I did find out who did it and paid the sob back with intrest!!
