1990 F150 4.9L EGR circulating through intake???
Old Sep 20, 2010 | 01:02 AM
court1100f's Avatar
court1100f
Let me clarify my question today as I was nurturing my 1990s 300Cid EFI alittle closer to good health. Plugs & Wires tomorrow comes the ACCEL high voltage electronic super coil. but anyway to my question. Ok after replacing plugs and wires. I went to reinstall the air intake tubes and noticed what sounds like Exhaust eminating from the throttle body. so my question after all that is this. IF the computers giving me a Code 31 during the Continuous Memory test which translates over to EGR Valve control sensor fault. is it hypothetically possible that Exhaust is being rerouted and fed right into the intake and causing the engines drivability problems???
Old Sep 20, 2010 | 06:10 AM
hav24wheel's Avatar
hav24wheel
possible. The egr would have to be stuck in the open potion. Witch is a somewhat common issuE
Old Sep 20, 2010 | 06:51 AM
CLR f-150's Avatar
CLR f-150
I had 3 codes telling me that the EGR wasn't working, so I started with the EVP sensor. That didn't work so I replaced the EGR valve body, that was it. I unpluged the battery for a good 30 minutes, plugged it back in and ive been code free for months. Good luck with yours
Old Sep 20, 2010 | 09:10 AM
Conanski's Avatar
Conanski
The EGR valve should be closed at idle so you have a problem and yes exhaust gasses being passed when they shouldn't be will cause hesitation and drivability issues. Start by simply removing the vacuum line on the EGR valve while the engine is running, if there is vacuum present on the hose you have a bad EGR Vacuum Regulator(EVR) or a potential short in the control wires that is holding the EVR open. If there is no vacuum in the line but the valve still passes exhaust then it is stuck or faulty so replace it.
Old Sep 20, 2010 | 04:58 PM
court1100f's Avatar
court1100f
BUSTED!!!!!! You hit the nail on the head!!! The EVR as you refered to it is sucking vacuum at idle and throughout the RPM range. A question that came up while researching the cost of that particular part Oreilly's does not have a quote on quote *EVR* but they do have this little item List: EGR Vacuum Solenoid - 1990 Ford F-150 | O'Reilly Auto Parts Is this what I want/need for the "Old Guy/Old Man" ????
eakermeld
20
Mar 13, 2015 02:34 PM
cherrybomb37
Jan 22, 2015 12:34 AM
Michael Manglos
Feb 8, 2014 11:22 PM
1990-f250
Jul 19, 2013 07:37 PM
Tommyquest
Apr 18, 2003 06:12 AM
