460 Exhaust Manifold Questions
on
I believe the 94 has F3TE heads which I believe has slightly bigger ports so I would think that the lower intake and manifold would be slightly bigger too however I am not sure.
I am curious though on what others say on the intake manifold as I have both a stock 91 intake and one with a F3part number which I believe is off a later 460 and curious which one I should run on our 91 460.
Trav
Trav
Trav
Trav
That's for the intake, right? I couldn't find any concrete info on that. Several places said all will fit, some said 88-92 and 93-97. So confusing.
I have just about figured out that the exhaust manifolds do have different ports for the EGR, but still don't know on port size and bolt pattern.
I'm gathering up parts for a repower for my truck. I'm going to do some porting on the intake and cast manifolds. If the exhaust manifolds don't turn out to suit me, I'll go with headers.
EGR fitting is just something I will deal with. I will get JY ones that don't have the AIR fittings cause them things are a real PITA! If I end up going with headers, I'll go with long tubes. If I'm going to go thru the trouble fitting headers, it's going to be for the maximum gain. But I really want to try ported manifolds. EXTRA WORK+DIFFERENT=FUN, right? Maybe?
I have my eye on a set of heads that have larger ports and valves. I'll get them soon. Maybe just a little clean-up on the intake. Not enough to gain on the exh manifolds to make it worth it? Or are they just made wrong for flow?
