How do i test my GP relay?
Old Sep 19, 2010 | 11:39 PM
robles4242's Avatar
robles4242
I have been searching my haynes book for over an hour looking for any info i can on my glow plugs relay. I want to start here before i go digging under valve colvers.
Does anyone know what it should be reading or how i give it a test? Im new to this going into a diesel motor thing.
Old Sep 19, 2010 | 11:53 PM
twags6's Avatar
twags6
One of the big posts should have battery voltage at all time. The other big post will have power only when the PCM turns the gp's on. Have a helper turn the truck to "on" while you measure the volts on both big posts. They should be pretty close to each other. If you're getting a difference of more then a volt or two, the contacts inside are burnt and the relay should be replaced.
IIRC, one of the small posts will also have battery voltage all the time, the other post is hooked to the PCM and gets grounded to turn on the relay.
Old Sep 20, 2010 | 06:56 AM
Ponyboychris's Avatar
Ponyboychris
Read the first part of this link: Welcome to guzzle's Stancor GPR replacement Mod Web Page
Oldschoolfordlover86
Jun 29, 2014 03:40 PM
centralNH
May 20, 2014 07:00 PM
RFD_Truckie
Electrical Systems/Wiring
Jul 10, 2009 06:00 PM
dyarumian
1978 - 1996 Big Bronco
20
Apr 11, 2004 12:05 PM
mlkull
1983 - 2012 Ranger & B-Series
Jan 15, 2003 07:43 PM
