Need Help
Old Sep 19, 2010 | 06:21 PM
compconcrete's Avatar
compconcrete
7th Gear
Need Help
need tech help, changed oil & filter, Drove truck Approx 400mi,doing 65 mph check engine light came on,on bridge could not stop for 2 mi,slowed down for traffic engine shut down,would not start,towed in too dealership,they retrieve codes P2291 ICP too low, P2290 ICP too low,special tool found both valve cover leaking STC fitting leaking air ,they say needs repair high pressure lines at dummy plugs and repair ICP ten retest estimate $3,400.00 warranty expired 5 yrs 7 mo 63000 mi paid $300 for test ,$160 for tow. Picked up truck with trailer and brought home,truck was 100 mi away,will any emissions warranty cover this, 7yr 70,000 mi defects
Old Sep 19, 2010 | 06:41 PM
69cj's Avatar
69cj
How can anyone give you warranty info when they don't even know what truck you have.
Old Sep 19, 2010 | 06:57 PM
compconcrete
7th Gear
sorry new to this,05 F250 SD
Old Sep 19, 2010 | 07:02 PM
69cj's Avatar
69cj
Warranty is 5 yrs./ 100,000 miles which ever comes 1st. Emissions warranty I think is 7 yrs, 80,000 miles but I don't thing the hpop system comes under the emissions warranty. If anyone knows better please correct me.
Old Sep 19, 2010 | 07:06 PM
compconcrete
7th Gear
don"t you think $3400 is extreme for a truck that was running great,then just shut down
Old Sep 19, 2010 | 07:19 PM
69cj's Avatar
69cj
Price is dependant on what the parts and labor costs, not when or how it shuts down.
Old Sep 19, 2010 | 07:25 PM
compconcrete
7th Gear
been looking at other owners with same mileage 60000> 80000 and just over 5 yrs, paid lots of money for truck that has such low milage and shuts down
Old Sep 19, 2010 | 07:33 PM
69cj's Avatar
69cj
I still don't understand where your coming from. Cost is labor and parts, bottom line. You are free to take it elsewhere. I would if I thought I was getting ripped off or I would tackle it myself. That last option could be more costly depending on capabilities. Don't forget you do pay for knowledge and experience and the investment that the tech may have in specialized tools. Also the dealership doesn't get there property for free.
Old Sep 19, 2010 | 07:56 PM
compconcrete
7th Gear
I don't think I am explaining myself. This seems to be only a problem to Ford owners that have changed the oil themselves. Now if Ford has sold you a vehicle that cannot have the oil changed by the owner. Then Ford needs to tell the owner that.
Old Sep 19, 2010 | 08:01 PM
bismic's Avatar
bismic
It really has nothing to do with the oil change unless you are using the wrong oil, wrong filter, or you are waiting too long for the oil change.
The STC fitting leaking is not COMPLETELY independent of the factors described above, but if everything is done properly it is. It is just a fact that the 05's are prone to this failure - unfortunately.
Edit -
Personally, I think you can find places to get it done more cheaply (or even tackle it yourself).
Old Sep 19, 2010 | 08:55 PM
compconcrete
7th Gear
so where do I start, if I was to repair myself as I don" have $3400,
Old Sep 19, 2010 | 09:25 PM
compconcrete
7th Gear
Could they? get an accurate pressure reading if the couldn't start the truck?
Renard
Jan 6, 2014 10:04 PM
A H DEVELOPMENT
20
Mar 8, 2010 06:06 PM
2millwork
16
Jan 28, 2010 11:27 AM
GrizzlyPiet
Nov 30, 2008 09:21 PM
Benjoman
Aug 6, 2007 10:09 PM
