the passenger side window will go up and down but will not go up completely when i press the button it goes up and about 1/2" from the top it stops and makes a thudding sound like something is stuck. i have taken the door apart and the assembly when applied enough pressure will go all the way up but it take an ample amount of force. so i don't know if the motor is just not strong enough anymore or if it needs to be reset to a different location. i tried to reference a maintenance manual but it was really vague and did not give me a really good answer
I am suspecting the gears on the swing arm. They seem to fail. Good news is replacements are not that expensive and come with new motor. Somewhere around here I did a writeup on this.
First step is to know specifically what year we are talking about (edit your signature lines with the info for future postings!).
