7.3
Old Sep 18, 2010 | 07:52 PM
Vinford's Avatar
Vinford
I started a thread somewhere and i cant find it.
It was about how to tell a 6.9 from a 7.3?
The truck is a 1989 F-350 4x4 dually flatdeck.
It has a 5 spd.
Old Sep 18, 2010 | 08:24 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
theses are all your threads that you started in the idi section:
Ford Truck Enthusiasts Forums - Search Results
does that link work i wounder lol.
you may have asked what the difference is between the two idi's,but it looks like you may not have done so in a thread you started,and or,perhaps not in the idi section.
back in '07 you asked the difference between the psd and the idi.maybe thats the one you are thinking of?
https://www.ford-trucks.com/forums/6...diffrence.html
Old Sep 18, 2010 | 09:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle
In that picture in the area from 11 to 12 O'clock on the blue circle around the temp sending unit there is a number stamped in the block on the flat area.
Before you get in as far as the valley pan, behind and right of the IP drive gear cover and left of the head.
Should be something like 6.9D U2U 435779 if you have a late version of the 6.9.
If you have a 7.3 the first numbers will be 7.3D.
Head bolts, 7/16" 12 point heads, 6.9
Head bolts, 1/2" 12 point heads, 7.3
You can see several head bolts above the exhaust manifolds but below the rocker covers on both heads.
Purple circle, 10 and 2 o'clock the circle is over two of my head studs where you would have head bolt heads.
Old Sep 18, 2010 | 09:04 PM
oreocreaming's Avatar
oreocreaming
It has a 5 spd.
click on your own name, then click on find posts by user.
Vinford's Avatar
Vinford
I thought I asked here about a week ago.
I got some good answers on how to tell the diffrence but I didnt really read them because i didnt have the truck home.
Now i have the truck and cant find the thread?
Old Sep 18, 2010 | 09:06 PM
Vinford's Avatar
Vinford
Dave thats near the lefdt head?
Old Sep 18, 2010 | 09:10 PM
oreocreaming
https://www.ford-trucks.com/forums/s...archid=2604190
Old Sep 18, 2010 | 09:41 PM
Vinford's Avatar
Vinford
Found it thanks to you.
It is called "89".
Old Sep 18, 2010 | 10:05 PM
awhtx's Avatar
awhtx
In regards to the head bolts- what size socket fits each of the bolts? Lots of 7/16" bolts used on Fords have 11/16" heads. Do the 1/2" bolts take a 3/4" socket?
Old Sep 18, 2010 | 11:06 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Dave gave you the Socket sizes ...
The 6.9 uses a 7/16" 12 point socket on the head bolts!
The 7.3 uses a 1/2" 12 point socket on the head bolts!
-Enjoy
fh : )_~
Old Sep 18, 2010 | 11:30 PM
Vinford's Avatar
Vinford
-Enjoy
fh : )_~
I dont think the head bolts would take a 7/16 wrench or socket?
7/16 bolts maybe?
Old Sep 19, 2010 | 12:54 AM
Festus Hagen
Methanoholic
Yup they sure do for the 6.9 ... 7/16" 12 point socket!
That is the easiest and quickest way to tell a 6.9 from a 7.3 ...
-Enjoy
fh : )_~
Old Sep 19, 2010 | 01:09 AM
Rick Wallace's Avatar
Rick Wallace
When will you dorks learn not to question Dave or Festus?? If they say it ,,believe it. Yes Im in a foul mood this morning,,,thank you very much.
Old Sep 19, 2010 | 02:07 PM
Vinford's Avatar
Vinford
1/2 for me...........
Old Sep 19, 2010 | 05:46 PM
Festus Hagen
Methanoholic
That would indicate it's a 7.3L.
-Enjoy
fh : )_~
Mr. 7.3 of Byram
Jan 25, 2015 06:22 AM
Jetmech6
Feb 25, 2014 06:53 PM
bigtexan99
18
Apr 12, 2013 02:02 PM
A/Ox4
May 28, 2011 08:26 PM
fordhaulinallis
Engine Swaps
Nov 6, 2005 10:39 PM
