Soft brake pedal
Old Apr 16, 2010 | 06:27 PM
Major94's Avatar
Major94
Soft brake pedal
So Im goin along, put on the brakes and It stops. But when on the brakes it gets soft. But if you pump them once they get hard again. But with the pedal down the brake pressure light comes on. But when you idle up it turns off. I put on front pads, and nothing changed. It has new shoes as of 3 months ago. Im not loosing fluid. What is my problem.....hey hey be nice Im talkin about my truck not me personally.
Old Apr 16, 2010 | 07:15 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
the first thing I would do is to readjust the rear brakes, purge for take any air in the system and check the brake fluid in the reservoir.
Old Apr 16, 2010 | 07:18 PM
Major94's Avatar
Major94
Originally Posted by RÖENTGEEP
the first thing I would do is to readjust the rear brakes and check the brake fluid in the reservoir.
Sorry I didnt say that. but that was the first thing I did. I thaught that would be a give-me.
Whal else do you think?
Old Apr 16, 2010 | 07:22 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
What about the air in the lines, did you purged it.
Old Apr 16, 2010 | 07:23 PM
fordpride's Avatar
fordpride
check the rubber gasket in the cap of the reservoir it could be sucking air in the system
Old Apr 16, 2010 | 07:24 PM
fordpride's Avatar
fordpride
dang you got it frist
Old Apr 16, 2010 | 07:32 PM
59JEEPSTANG's Avatar
59JEEPSTANG
If I recall correctly when I was changing my brakefluid (yes someone does that) I ran into the same thing. If I remember correctly the proportioning valve got off center and had to bleed in certain sequence. Sorry can't remember sequence. It could also be you master cylinder, but since it started after replacing pads I would say the valve is off center. Or I may be a little off center.
Good Luck,
Paul
Old Apr 16, 2010 | 07:40 PM
Major94's Avatar
Major94
Good Luck,
Paul
No it started on its own, and I then did front pads thinking it would stop,cuz they needed replaced. Umm could it possibly be the vacuum pump starting to go out. And If someone has the bleeding sequence that would be worth a try, just for giggles.
Old Apr 16, 2010 | 07:47 PM
fordpride's Avatar
fordpride
if the V/P WAS GOING OUT IT WOULD BE HARDER
Old Apr 16, 2010 | 07:48 PM
fordpride's Avatar
fordpride
try bleeding your brakes frist and see what happens
Old Apr 16, 2010 | 07:51 PM
Major94's Avatar
Major94
I still need the sequence on bleeding the brakes. Anybody??
Thanks
Old Apr 16, 2010 | 07:59 PM
fordpride's Avatar
fordpride
I dont know of any sequence. i get some to pump them 4or5 times and hold them down then undo the bleeder screw let the pedal go to the floor and hold close bleeder screw and repeat 3 times on each wheel checking fluid after each wheel
Old Apr 16, 2010 | 09:15 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Ideally you should bleed the farest valve first then to the closest one, including the proportional valve in the sequence and totally agree with checking the brake fluid after each bleeding valve.
Old Apr 16, 2010 | 10:04 PM
fordpride's Avatar
fordpride
Thanks i didn't know that. how do you bleed the proportional vavle.
Old Apr 19, 2010 | 10:41 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
It has the same kind of bleeder as the one on the wheels. Here is a pic with the bleeder (arrow)
