2000 F350 DUALLY GVWR IS 11200...TOWING A CAMPER AT 9400 PLUS PEOPLE AND GEAR SO IM PROBABLY LOOKING AT 22000. I HAVE A ECM? CHIP THAT SAYS NVK4 80. WHICH I BELIEVE IS FOR ECONOMY. MY ISSUE IS TOWING...I CANT SEEM TO GET UP HILLS UNLESS I SLAM THE PEDAL TO THE FLOOR AND FROM STANDING STILL IF IM AT AN INCLINE I HAVE DIFFICULTY GOING UP HILL..EVEN DOWNHILL THE TRUCK ACTUALLY SEEMS TO SLOW DOWN..I DONT KNOW IF ITS A TRANNY ISSUE OR WHAT..ANY INSIGHT TO THIS WOULD BE APPRECIATED..ITS ACTUALLY A HEADACHE FOR ME TO DO NOW...IVE PULLED THE CHIP AND IT ACTUALLY SEEMS TO TOW ALITTLE BETTER BUT I DONT KNOW WHERE TO TURN..A BETTER CHIP MAYBE? I JUST DONT SEEM TO HAVE THE POWER THAT I BELIEVE I SHOULD HAVE..
Reason: ADD
Maybe a little more operational information and we can help. Any smoke? Check engine light? Stumbling? Oh, and all caps sounds like you are shouting...
Sorry for the Caps...I just did a MBRP 4" stainless exhaust, single..I have tranny gauge, Boost gauge and egt gauge..And Yes..when I was slamming pedal the check engine light came on then it went off...Happenned a couple of times with the chip in but none when I removed it..My boost will go up to 22-24 or so during this time too and EGTs generally dont go over 1100. I have no issues with start up or the way she runs, Its just the towing
Clogged fuel pickup screens in the fuel tank.
Classic symptoms as you describe.
This is what happened to my truck last year. It was slowing down more and more going uphill, but would drive just fine downhill. I have manual transmission.
In normal operation my 7.3 pulls 20k sets even on 7% grades without downshifting for about 1/2 mile. All stock.
Always has been this way...Whenever I tow..My BP goes up...And its an automatic transmission...By the way...Is that filter or scxreen an easy job? Do it yourself job?
It should be a DIY job. Much better of course if you have a 2nd person. If you are going to check the filter screens, you might as well do the Hutch and Harpoon mod while you are there with the tank down. Try to run as much fuel out and then drop the tank.
