5.8L question
Old Sep 17, 2010 | 09:09 AM
f150forever's Avatar
f150forever
5.8L question
I have searched the forums with no luck. I have always been curious why my 95 with the 5.8L idles rougher than my 96 with the 5.0L. It is almost like the 5.8L has a skip at idle causing it to vibrate and idle rougher but off idle it is smooth and runs great. I always thought this was a problem with just my truck but I noticed all of my friends trucks do the same thing. I have not been able to verify this or find any explanation for this other than someone told me it was due to valve overlap. Does anyone else know anything about this?
Old Sep 17, 2010 | 09:39 AM
96ford250's Avatar
96ford250
what rpm is ur motor idling at? if its like 900 to 1000 its probly a vacuum leak i jus went through the task of pulling all the plastic lines and replacing them with rubber lines.
Conanski's Avatar
Conanski
A 5.8 should idle as smoothly as the 5.0 so the truck has issues... could be a vacuum leak, bad plug wires, or something similar.
haulinit
13
Mar 4, 2026 10:23 AM
DMattera
15
Oct 3, 2014 10:15 PM
2006powerstroke90
Jun 25, 2011 02:39 AM
oldmansimek
Jan 15, 2010 04:53 PM
shortblock2000
Nov 25, 2006 01:44 PM
