rough over 2000 rpm
Old Aug 18, 2003 | 02:26 AM
shortblock2000's Avatar
shortblock2000
rough over 2000 rpm
My 1986 ford f10 5.8 liter carbureted engine runs smooth at idle and at rpm up to 1800to 2000 ....but when over it starts to run rougher and wants to backfire when I let off the gass down the road. What is this and is it a simple job I can handle? Please help.
Old Nov 25, 2006 | 11:57 AM
VirginiaWiFinder's Avatar
VirginiaWiFinder
Bump...b/c I have the same issue.
Old Nov 25, 2006 | 01:24 PM
ford302stang's Avatar
ford302stang
have u tried timing it, sounds like it is out of time
Old Nov 25, 2006 | 01:44 PM
big hoss 29's Avatar
big hoss 29
Sounds more like a vacuum leak to me. Try spraying some carb cleaner around the base of the carb while it's running and see if the idle comes up. Also check any vacuum lines to see if they're cracked or split.
Baxter2110
Feb 3, 2015 05:48 PM
Sams_animal
Sep 15, 2014 09:14 AM
KSims1868
30
May 17, 2009 11:19 PM
DixieOffroad89
16
May 14, 2008 03:11 PM
TLakeHarley
Bronco II
Feb 2, 2007 05:12 PM
