Oil & Lubrication
Oil Recommedation
Old Sep 16, 2010 | 10:53 PM
Hawkfan98's Avatar
Hawkfan98
Oil Recommedation
First off since this is my first post I will say hello from Bremerton, WA. So here's the story, just bought a '93 F-150 4X4, 4.9l in-line-6, 5sp manual, 200k miles. Same owner since '94 and has been well maintained. My question is which oil should I be using? After searching around here and BITOG I have narrowed it down to: Rotella T6 5W-40, Rotella 15W-40 dino, and Delo 400 15W-40. My concerns would be:
-Is 15W-40 okay to use here in the NW? We get down in the 20’s maybe a handful of nights in the winter
-Is it okay or even recommend switching to synthetic after the truck has only had dino for all of its 200k miles?
Thanks for the help and feel free to recommend other oils that might be better than these three.
Old Sep 17, 2010 | 11:16 PM
jimandmandy's Avatar
jimandmandy
Welcome to FTE and the Oil and Lubrication Forum!
Delo 400 is my favorite for older engines. Since 15w is good down to +4F according to SAE J300, and I have used it up here in the mountains with winter morning temperatures frequently in the 20's, I see no problem. Rotella T6 5W-40 may increase gas mileage for short trips and it is my favorite motorcycle oil. While it is not PAO and wont harm seals, syn tends to find small leaks and amplifies them.
Jim
Old Sep 18, 2010 | 08:33 AM
Hawkfan98's Avatar
Hawkfan98
Is Delo 400 still available or is it now all Delo 400 LE? Did the formulation/quality really change much? How does the Rotella 15W-40 compare to Delo 400?
Old Sep 20, 2010 | 08:47 AM
jimandmandy
The LE version of Delo 400 still has 1200ppm zinc so I dont know what all the fuss is about. What has been reduced is TBN (total base number), a non-issue in gasoline engines and really a non-issue for any on-road diesel, due to the ultra low sulfur content of fuel today. Moly is the reason I prefer Delo over Rotella in everything except motorcycles with wet clutches.
Old Sep 22, 2010 | 01:07 PM
Hawkfan98's Avatar
Hawkfan98
Moly? What benefit does it have?
Old Sep 22, 2010 | 04:02 PM
jimandmandy
Molybdenum trialkyldithiocarbamate (MoTDC) is another extreme pressure lubricant, similar to ZDDP in that it prevents metal-to-metal direct contact when the hydrodynamic oil film is squeezed out. Upper piston rings are coated with Moly compounds and now Honda even coats piston skirts with it. Delo 400 is too "slippery" for wet motorcycle clutches, while Rotella is approved for Japanese motorcycles (JASO MA) due to lack of Moly. To me, thats a good thing in all other gasoline and diesel engines. ZDDP somehow does not change frictional properties, but acts only as an EP lube and antioxidant.
F3504ME
Feb 17, 2014 07:09 PM
tankd72
Nov 14, 2013 06:44 PM
PaysonPSD
30
Mar 2, 2008 10:16 PM
JBB_01F250
General Diesel Discussion
Oct 26, 2006 01:19 PM
Xyzzy
Oil & Lubrication
18
Nov 20, 2003 10:33 PM
