Sponsored by: Auxito
4R70W Issues
Old Sep 16, 2010 | 06:56 PM
matt_791's Avatar
matt_791
4R70W Issues
Hi everyone.
My brother in law has a 2003 F-150 King Ranch, 5.4L 4X4 with a 4R70W. Truck used to work great, but he decided to go mud bogging with it, had to get it towed home (not the first time for this truck, lucky for him I'm a mechanic and own a F-350) Serpentine belt tensioner self destructed. SO I've been busy over the last two weeks cleaning/changing fluids/adjusting/freeing things up on it for him. It was working fine up until recently. Now hes complaining that as he's driving along on trips longer than an hour, at around 45-55 mph his truck will start to shudder, then it will downshift or the t/c unlocks. He thinks its the tranny itself. He has a cel on in the dash. The truck was VERY full of mud after the trip, he pressure washed the engine (and probably all the electrical) I made sure to clean out the intake and maf and repleaced the air filter. I read in other posts that a bad coil pack could cause some shuddering, but no one mentions a downshift issue. Hope someone ahs some idears for me. Thanks in advance.
Old Sep 16, 2010 | 07:30 PM
Bluegrass 7's Avatar
Bluegrass 7
Again, the tell tale sign is the miss between 45 and 60 mph.
It's one coil with low output.
There is a lengthy explaination that discribes the cause and effect of this condition that does not set a code because it's not a hard fault.
Find the one and you find the miss..
Good luck.
Old Sep 17, 2010 | 12:35 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Also verify that the holes that the spark plugs are in are clean and dry as well. If the rubber boots that cover the plugs dont seal correcly they can let water in and create shorts.
kmeifert
1997 - 2003 F150
76
Dec 16, 2023 09:37 PM
nicebenz68
Apr 2, 2013 07:25 PM
scotty088
6.7L Power Stroke Diesel
Jan 28, 2012 11:21 PM
Brian Uhlenhake
19
Jan 25, 2011 09:19 PM
