4x4 switch problem?
Old Sep 16, 2010 | 05:05 PM
daleyboy's Avatar
daleyboy
4x4 switch problem?
i have a 2003 f250 super duty crew cab. It is stuck in 4x4 low. i thought it might be a fuse to the 4x4 switch, but was not. when i switch it from 2wd high to 4 high to 4 low, the light on the dash says 4x4 low. any help will be appreciated
Old Sep 16, 2010 | 05:30 PM
mikeyc0120's Avatar
mikeyc0120
Ive had this prob a few times myself and so have a handful of others. What I'm reading is that you have to be in neutral with your foot on the brake. If that doesn't work it was recommended to unplug the transfer case plug, clean it and seal with die-electric grease. Let me know if you figure it out to be anything else so I can check mine too.
Old Sep 16, 2010 | 06:06 PM
daleyboy's Avatar
daleyboy
Hey Mikey your the man. went out started it up, put it in neutral, foot on the brake, turned the switch and the 4x4 low light went out, thanks!!!!!
Old Sep 16, 2010 | 06:49 PM
mikeyc0120's Avatar
mikeyc0120
Noooooooooo problem. Now you know! (and knowing is half the battle! lol)
caddy
6.4L Power Stroke Diesel
Apr 5, 2014 01:23 PM
Jbru167
Jan 4, 2010 11:36 AM
97C5ENVY
Dec 26, 2009 03:14 PM
tonymac15
General Automotive Discussion
Dec 19, 2009 01:25 PM
WWBeast
Sep 23, 2007 08:58 AM
