General Automotive Discussion
MAP sensor bracket - GM
Old Sep 16, 2010 | 04:05 PM
ford2go's Avatar
ford2go
Hi,
The MAP sensor bracket is gone from my 84 Fiero
Should be under the car, but I can't find it.
I know that GM probably used this same sensor on a lot of TBI cars
Any thoughts on where to get one, or how to make one?
If you say junk yard, please give me some alternate vehicles to search.
Thanks,
hj
Old Sep 17, 2010 | 09:32 AM
quaddriver's Avatar
quaddriver
how do you know it is gone? is the MAP just a hanging?
any boneyard should have one, GM mounted them on firewalls and intake manifolds so select one from a yard that is close to what you have.
Old Sep 18, 2010 | 12:41 AM
ford2go's Avatar
ford2go
Problem (hopefully ) solved.
It's a Dorman 41113 that I can get from Oreilly. They are $1.39 for a card of 2,
This is the same little gizmo that GM used on the pvc filter in the air cleaner, and on virtually every MAP sensor.
There are 40 pages of applications on the Dorman site.
I know it's off because I had the sensor out while I was doing some maintenance. I hung the clip on it, reminding myself to be careful.....
daltonjamesadams
Nov 19, 2013 05:34 PM
el01
2004 - 2008 F150
Feb 13, 2011 06:00 PM
four-sixty-power
15
Dec 10, 2010 12:45 AM
MagKarl
Jul 17, 2007 07:56 PM
rufaast
May 4, 2006 01:30 PM
