2010 F150
Let me introduce you to the search function. Saves a lot of time and you get answers a lot quicker.
These will get you started:
https://www.ford-trucks.com/forums/9...t=transmission
https://www.ford-trucks.com/forums/9...g-problem.html
Read this:
The BEST Break for a new car. "very long" - 2011 Camaro Z28 Camaro Forum / Camaro Z28 SS Forums - Camaro5.com
This is what I did to break in my 2010 Camaro and what I'm doing now to break in my 2010 Lariat
Don't worry that the engine, transmission, drivetrain of and F150 are completely different than a Camaro Z28.
It won't matter.
If you really want to break it in (hard), hook up a 10,000 lb trailer and head for the steepest mountain you can find. I'd make 10-20 trips at WOT up the mountain (stopping only to fill up with gas). Do not use the T/H mode (that way if you forget later - after the break in - your engine and transmission won't care).
Sorry tradosaurus, but IMHO this is the worst advice I've read in a while.
BTW, is the 2010 your first truck?
It won't matter.
Well actually.............When I had the engine replaced in my former '88 F-150, the tech (a well respected engine builder) told me to break her in like I intend to drive her. Now this was back in '95 when the engine was replaced on an antiquated piece of equipment by comparison.
I personally don't think it really matters considering all the fleet vehicles that are on the road with multiple drivers and they seem to hold up just fine.
We're also not talking about a race engine.
IMHO you can't rely on fleet vehicle history as an indicator. Very few of their owners post their 'issues' or repairs. Yeah they might be running fine when they're 5-10 years old, but how much money was spent repairing them? You'd need OASIS reports for a large sample (of both fleet and private) to prove the drive-it-like-you-stole-it break-in is better than following the manufacturer's guidelines.
Still a great discussion none the less.
My point is without strong evidence to the contrary (which neither you nor I have), why would anyone risk damaging the engine and/or drivetrain by not following the manufacturer's recommendations?
And you're right - this is a great discussion!
back at ya'
Actually when I just bought my '10 Focus and when I bought my '04 Expy, the owners manual said that for the first 1000 miles not to drive at the same continuous speeds and not to tow.
I'm assuming that after the first 1000 miles, anything that needs to be seated and worn in has more than likely done so.
I won't be getting my new truck until the spring when the 5.0L's are well into production so I have absolutely no experience with the new trucks.
BREAKING-IN YOUR VEHICLE
Your vehicle does not need an extensive break-in. Try not to drive continuously at the same speed for the first 1,000 miles (1,600 km) of new vehicle operation. Vary your speed frequently in order to give the moving parts a chance to break in.
Drive your new vehicle at least 1,000 miles (1,600 km) before towing a trailer. For more detailed information about towing a trailer, refer to Trailer towing in the Tires, Wheels and Loading chapter. Do not add friction modifier compounds or special break-in oils since these additives may prevent piston ring seating. See Engine oil in the Maintenance and Specifications chapter for more information on oil usage.
On the other hand, my John Deere's say to operate the tractors in the mid to upper load range for the first 100 hours (and do not idle for long periods) These tractors do use "break in" oil. BTW these are turbo charged diesels.
My 05 PSD says the same thing posted above, no towing, no break in oils, etc.
Kind of makes you wonder. Tractors are designed to work hard all of the time and they say "work it hard" and use break in oil. Ford seems to have a "standard" break in procedure for all of their vehicles whether gas, diesel or car or heavy duty truck.
Very interesting..
It won't matter.
I'm just varying it a lot harder.
But read the link I gave before you give your opinion.
I'll let you know how my truck turns out in 800 more miles!
I did. Driving it like you stole it or how you intend on using it in the future (towing 10k lbs) is a lot different than varying your speed (or not maintaning a constant speed for long distances).
Not to mention this thread is about the OP's transmission and potential issues, not the break in period.
Start your own thread.
