No heat ??
Old Sep 15, 2010 | 02:42 PM
smlford's Avatar
smlford
No heat ??
Well mornings are getting cooler and I went to put the heater on and .....nothing...no heat what so ever. This was after the engine had warmend up and the fan was running ...just blowing cool air.
Took it to a mechanic friend and he felt the hoses ( I ws wondering if it was a thermostat) but he said all the hoses were warm so he thought that perhaps there is a malfunction in one of the doors that opens the pathway for the air to enter the cab..
Any thoughts?
Old Sep 15, 2010 | 03:57 PM
87 XLT's Avatar
87 XLT
Yeah, if your temp gauge is showing normal temp & the hoses are hot i'd say your mechanic nailed it. The problem is with the blend door.
The blend door directs air thru the heater core. Looks like it's not doing that.
Could be a bad temp switch or blend door motor.
Old Sep 15, 2010 | 11:23 PM
g_k50's Avatar
g_k50
might be the vacuum line that operates the doors.
Old Sep 16, 2010 | 02:45 AM
michigan66's Avatar
michigan66
Check the articles in the Technical Information section, the one on "Blend Door Repair."
Old Oct 30, 2010 | 07:51 AM
smlford's Avatar
smlford
UPDATE
First, thanks for all the helpfull hints.
In doing a little research I wasn't really comfortable attacking what I though was the replacement of the blend door so I took it to the dealer.
They discovered that it was the blend door actuator (motor) that had failed and replaced it. The door was fine.
Cost about $250 but I now have all the heat I want!
RLKBOB
Dec 26, 2011 05:13 PM
Chaosracing
2004 - 2008 F150
Jan 23, 2011 07:20 AM
wylecoyote
Modular V10 (6.8l)
19
May 19, 2008 04:45 PM
herdfan75
Sep 5, 2005 06:46 AM
kritterkraz
Sep 5, 2003 09:08 PM
