Ignition won't turn
Old Sep 14, 2010 | 03:57 PM
O43x's Avatar
O43x
Ignition won't turn
Is anybody aware of some sort of a re-set switch on the ignition? I loosened my front bumper to put my new light bar on, now my ignition won't turn.
I've tried moving the gear shifter around, even rocked the truck back and forth to see if that's the problem....no dice!
On my '91 F250 there was a re-set switch in case of an accident, just wondering if my 2006 F250 has the same.
Any help?
Old Sep 14, 2010 | 06:41 PM
Headviking's Avatar
Headviking
Do you mean the key will not turn. If so try moving the steering wheel away from the lock position and turning the key. If you mean that it will nor start, there is a fuel cut off switch located at the foot well. Not sure if it's the passengers or the drivers.
Old Sep 14, 2010 | 08:25 PM
Young Gun's Avatar
Young Gun
Try a different key. My WT(02 F150) was working great then one day I got in and the key wouldn't turn. The key had finally worn enough not to move the tumblers.
Old Sep 14, 2010 | 09:26 PM
Headviking's Avatar
Headviking
Didn't think of that.
Old Sep 15, 2010 | 06:50 AM
DSMMH's Avatar
DSMMH
Any help?
Get the owners manual out and look in the fuse/relay section. I believe there is a dedicated relay that provides power to the starter solenoid. Swap that relay with a similar one and see what happens.
DSMMH
Old Sep 15, 2010 | 11:53 AM
69cj's Avatar
69cj
043X still hasn't clarified wether it's the key or the engine that is not turning.
Old Sep 15, 2010 | 12:13 PM
DSMMH's Avatar
DSMMH
Since he "moved the gear shifter around" and there is no "mechanical" reset switch from the OP, I assumed the mechanical key operation is OK and it is an electrical problem.
DSMMH
Old Sep 15, 2010 | 02:10 PM
thomabb's Avatar
thomabb
Does this truck have an auto transmission? You should not be able to move the gear shifter around if the ignition is off. Try turning the ignition farther towards the off direction.
Old Sep 15, 2010 | 02:47 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
As he's a newB, he prob figured it out and abandoned us......
Old Sep 15, 2010 | 03:01 PM
thomabb's Avatar
thomabb
Abandonment - great - 6 more months of therapy . . .
Wrench Bender 117
Feb 3, 2014 09:38 AM
Bandit91
Mar 12, 2012 11:36 AM
sjser
Nov 9, 2006 11:04 PM
Tricky Dick
Feb 12, 2004 08:08 PM
DaveTheSlave
Nov 28, 2003 07:13 AM
