hey was just wanting to see if any had a spider off an early 99 sd, they was not useing and wanted to sell or no where i could get one. called all over mo at junk yards and came up short. thanks
they are in high demand over in this forum and you wont have any luck, you can try the classifieds or go over to t he wanted section at Powerstrokenation dot com, ive had most luck over there, tons parts.
not sure i called a place 2 day they didnt have one but said if they did it would go 4 a 100 bucks, is it 2in and all like i need?? banks iwll sell all there pipeing and spider for 500 bucks just fell like you are buying a name there, and i have put all the weanch time in my self and wanna do my own ic, you guys no, let me know what your thinking on it, thanks!!
100 bucks ain't too bad, little high but I'd grab it if I needed it. To make sure its right, measure where the boots connect to it from the intakes. They should measure 2 3/8", superduty ones measure 3".
you wont find an early 99 spider for much under 100, go snake it while you can. if not you can make your own like i did, its not pretty but it does the job
Looked up a used engine on car-part.com for 1999 SD built before 12/6/98. Some of them denote *burned or *core only... Grabbed a pad and pen then started making phone calls. The worst parts were getting them to understand EXACTLY what you want and that it MUST be from a truck built before 12/98. I bet I called 20-30 places before I found this one in at a yard in Iowa, $110 shipped.
Not sure if this makes the price go up or down but I never mention that I'm trying to UPGRADE my truck, just that mine broke. I think that when they think your playing around instead of trying to get it fixed the price goes up.
Happy hunting.
Jason
yeah most pep dont understand what your wanting when you call, i found out you can take a sd 2000 and cut the 3in of and adapt it down 2 2in and make them work gotta weild a little or build it your self as posted up above
