Pistons
Old Feb 19, 2003 | 07:00 PM
workin hard's Avatar
workin hard
Pistons
Does anyone know a good mail order company that would carry pistons for a 400 I'am looking for a 9.1:1 and hear that Badger makes them but cannot find a source. Is there any one else that make a 400 high cr replacement pistion?
Thanks
Old Feb 19, 2003 | 07:57 PM
Bill_Beyer's Avatar
Bill_Beyer
Pistons
There's been many threads in this forum on pistons for the 400. I'd strongly suggest you do a search on "400" and "piston" and I'll bet you'll get more information than you know what to do with including the most recent (2 weeks or so) names and phone numbers to try to find the Ohio/Dynagear/Badger/Nylen/Ertel flat top 9:1 pistons.
Old Feb 19, 2003 | 11:02 PM
kopfenjager's Avatar
kopfenjager
Pistons
Watch out there is more info on pistons for a 400 than you'll know what too do with. Let's make it simple. Here is some info I got from Billy Freeman about 2 weeks ago. I ordered my pistons, from brian then. They are about 5ft away from me in my living room now. Good, luck there is not alot of them floating around.
ERTEL PISTONS 800-428-4591 ( call Brian in Texas # is at bottom)
1282P CAST.030 4.000x.300 TOP LAND, 1.635-1.640 COMP DIST (1.637)
.150 DP VALVE RELIEFS, .975 PIN .060 OFFSET, RING LAND= 3.600 DIA
2EA .0805 1EA .1885 (2x5/64+3/16) RING WIDTHS
LISTED AS- FORD 400 PERFORMANCE PISTON, AND FOR TRUCK LP GAS APPS
FOR 9.0:1 COMPRESSION. PLATEAU/GROOVE SKIRT FINISH TO PROVIDE
INCREASED OIL RETENTION ON SKIRT ENHANCING THE HYDRODYNAMIC WEDGE
OIL FILM. BROACHED SLOTS IN PIN BORE AND AN OIL HOLE IMPROVE
WRIST PIN OILING. BETTER THAN OEM CAST PISTONS INTENDED FOR 350-450HP
ENGINES TURNING UP TO 7,000 RPM. PISTONS HAVE CHAMFERED SKIRTS, WITH
REINFORCEMENT.
OHIO PISTON & PIN CO. 317-636-3531
PART # 1282P
COMPRESSION HEIGHT 1.637
RINGS 5/64, 5/64, 3/16
P/N FOR FLAT-TOP PISTONS FROM BADGER IS 40010F
The Ertel part number is 1282P but they won't sell them to you without an account so they had to crossreference the number with a company in texas and that one is 400-10S-and then the oversize (20 or 30 or whatever). The number to this place is 1888-855-9712- and ask for brian- and the race is on! they don't have many-good luck
TMI
Oct 15, 2008 08:29 PM
danlee
33
Sep 25, 2003 06:59 PM
Torque1st
Nov 25, 2002 02:19 PM
trinogt
24
Aug 20, 2002 07:08 PM
Nathan
Dec 3, 2000 11:30 AM
